| DuramaxForum n00b Join Date: Jan 2012 Location: Spring Tx
| Water Pump question... Ok i know that my 05 has a water pump that it's known for going out. My truck has told me I've had low coolant 3 times in the past 2 months. At first i didn't really assume there was a leak but now after a night of being parked in the driveway I'm seeing about a 6 inch wet spot. I see that it's not leaking much but i still need to fix the problem. My question is, why do the lly water pumps go out more than say a lbz or a lmm etc? And when i replace the pump, do i buy one from the auto parts store or is there an upgraded one where i won't have to do this again? Usually there is a solution and not just another pump that's going to go out in 50k... Anyone's advice appreciated. 05 lly Bully dog for towing and performance tunes. 4" exhaust 172k Sent from my DROID RAZR using AutoGuide.Com Free App |
| | eBay Motors #2 (permalink) | |||
| Baby maker extraordinaire Join Date: Jun 2011 Location: Farmington,NM
| My water pump started leaking out of the weep hole at 130K. I thought all OBS water pumps were alike?
__________________ 2006 Chevy LBZ 4WD CCSB Resonator sealed. plugged & sticked. re-routed. shimmed. 4" MBRP cat-back(too much drone). Alligator trans cooler hoses. Transgo Jr. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. Bilstein shocks. AC Delco batteries. Daily driver. ![]() Quote:
![]() Quote:
| Idk but i want to know why they go out? I hear people changing them with Less than 50k. I know things wear out but still. Sent from my DROID RAZR using AutoGuide.Com Free App |
| I really hope I'll only have to do this one time so if there is an upgraded water pump and someone would show me where to get one that would be great. Sent from my DROID RAZR |
| Senior Member Join Date: Oct 2008 Location: Belvidere,il
| Quote:
Sent from a black cloud and the smell of burnt rubber
__________________ 04 CCSB LB7 IIs483 over IIs366 ,carillos,cut and coated lb7 slugs,ported heads,RDL downpipe uppipes manifolds ,efi live with dsp5,Big Dipper stage 4,4 inch out the back, ram air keystone hood,US Speedoo fox racing shocks cluster,rolling on hummers,and wraped in silverbirch. And some wicked tunning from Bo-Bo (Bob Olson)11.64 @117 ![]() Originally Posted by hllbllylmsne Sounds like you screwed up the seat to steering wheel linkage, no real fix for it, sorry | |
| Very few water pumps go out under 100k miles. Parts do wear out. I replaced the waterpump on my LLY, when I did the head gaskets at 95k miles. Neither had a problem. I called it preventive maintenance.
| | eBay Motors #7 (permalink) | |
| Quote:
Sent from my DROID RAZR | |
| DuramaxForum n00b Join Date: Dec 2012
| Order the water pump from merchant auto. They tig weld the propeller to the pressed shaft. The reason I think they go us because they are gear driven all that motor vibration is absorbed in those O rings and eventually wear em out that's my thoughts. If u have questions about replacing it hit me up I've gotten pretty darn quick at them |
