| Senior Member Join Date: Apr 2009 Location: Green Mountian State
| Diagnosis help on nbsu Trying to figure these tranny code to confirm a nbsu failure. Tranny indicator is intermittent and shows the physical signs/clunks of the nbsu problem, but here are the codes with the problem. P0700- believe this turns of the check engine light Unk. B1440 - no idea can't figure out Tcm p0562- again can't find this definition. Tcm po872- believe this is limp more if my research is correct. So do these code match up with a faulty nbsu? Thanks. The truck is a 04 lly all stock! Not the one in my sig
__________________ 2006 2500HD Crew LLY EFI Live...4" exhaust...Transgo JR...Blocked... EDGE EVO RACE as a monitor AMSOIL nose to tail Don't blow smoke, it confuses treehuggers into discontinuing the use of soap, which gives normal people a headache. |
| DuramaxForum Veteran ![]() Join Date: Jun 2012 Location: Choctaw, OK
| P0700- refers to a transmission control system malfunction b1440- power mode master input circut mismatch Tcm p0562-System voltage low(tcm).transmission control module Tcm po872-Pressure switch E, usualy means a stuck E shift valve
__________________ My LMM Build Thread 08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves..... |
| | eBay Motors #3 (permalink) | |
| Quote:
Do any of these issue correspond with a failed NBSU switch on the 5 speed Allison? To me the power mode mismatch and TCM low voltage could correspond with the corrosion issues that the switch usually fails with. Thanks again for the code definitions!
__________________ 2006 2500HD Crew LLY EFI Live...4" exhaust...Transgo JR...Blocked... EDGE EVO RACE as a monitor AMSOIL nose to tail Don't blow smoke, it confuses treehuggers into discontinuing the use of soap, which gives normal people a headache. | |
