Pressure in cooling system - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 12-25-2012, 11:32 AM Thread Starter
GTwannabe's Avatar
My 04.5 LLY is running fine, does not overheat, but even if I let it sit overnight and crank it cold, let it run for about a minute then shut it off, I have to slowly crack open the top on the coolant resevoir slowly. It is building enough pressure just from running a minute that I have to take my time taking the cap off to keep it from blowing the top off and blowing out the coolant from the resevoir.
If I drive it and get it up to running temp it will just start forcing it out of the overflow tube onto the ground. What would cause it to build up this much pressure? Cracked head? Blown head gasket? Causing compression to get into the cooling system and build pressure? That is what my 99 Trans Am did. Thats the only thing I can figure. Any help or suggestions are GREATLY appreciated. Thanks. And Merry CHRISTmas.
GTwannabe is offline
post #2 of 8 (permalink) Old 12-25-2012, 11:35 AM
BlackBetty06's Avatar
Sounds like your head gasket(s) are blown. I'm sure others will chime in too though. Good time to do studs!!!
DD: 2006 Duramax Diesel Black CCSB: 4" straight pipe: Big Dipper Trans: Banks Ram Air intake: ATP DSP5: BD Manifold: Air Dog II: resonator deleted: all on mod: B5+ every tank
491 HP/ 1018 TQ(Edge Evo Race LVL 7 numbers)
Work Truck: 2016 transit 250 Eco-boost
My First Truck: 1990 Chevy 1500 sport reg cab 4x2 5.SP Man with 4.3v6.
BlackBetty06 is offline
post #3 of 8 (permalink) Old 12-25-2012, 12:26 PM
ByrdDog's Avatar
X 2. If it sits overnight, is the upper radiator hose rock hard in the morning? That's another indication of HG's.
2011 3500HD 4x4 - EFI Live by Kory Willis, 4" exhaust, EGR blocked, Insight CTS2, AirDog II
1960 F-250 4x4
ByrdDog is offline
post #4 of 8 (permalink) Old 12-25-2012, 01:01 PM
38bulley's Avatar
Yup have the same issue it's defiantly the head gaskets.
04 gmc sierra 2500hd lb7/rg/lb/zf6/4x4
Efi live dsp5 switch, snow performance methanol kit,raptor 165 pump,southend 3250 dual disk,k&n intake,4" straight pipe exhaust,billet tie rods,18" motto wheels,275 nittio a/t grapplers ,traction bars,stock turbo,stock tranny,stock cp3 and injectors
38bulley is offline
post #5 of 8 (permalink) Old 12-25-2012, 01:06 PM
Join the club, i have pretty much the same problem. will be doing more than a few upgrades while im that deep into the engine
2004.5 LLY
-straight 4" exhaust
-PCV reroute
-Sinister EGRD
-LBZ turbo MP/resonator plug
-EFILive dsp5(IdahoRob)
-4" lift sitting on Toyo open country M/T 35's
"A person who never made a mistake never tried anything new."
-Albert Einstein
bryant is offline
post #6 of 8 (permalink) Old 12-25-2012, 01:08 PM
Lincoln Diesel
Aaron@LDS's Avatar
It sounds like Head Gaskets. It's not uncommon for a LLY to get a blown gasket. It also might be the radiator cap but I doubt it, because it builds pressure so fast. It should only build pressure from the heat.
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #7 of 8 (permalink) Old 12-25-2012, 02:20 PM Thread Starter
GTwannabe's Avatar
How much would I be looking at to replace the gaskets?
post #8 of 8 (permalink) Old 12-25-2012, 03:10 PM
Administrator
jc1843's Avatar
book time is about 35 hours of labor. Plus parts--gaskets [$200]and new bolts--[$100] most use studs-[$600]. Should also consider replacing the water pump-- if it is original.
Yes, you have a bad head gasket-- Sorry.
jc1843 is online now
