Looking at buying an lly but... - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 01-01-2013, 08:07 PM   eBay Motors  #11 (permalink)
FARMBOY26's Avatar
i dont see y some people say that the 04.5-05 duramax motors are not as good i dont know why i have a 04.5 and i have no problems with mine
FARMBOY26 is offline   Reply With Quote
Old 01-01-2013, 09:58 PM   eBay Motors  #12 (permalink)
jacobdewey's Avatar
Have you ever had an LB7 or LBZ to compare it to? I own both lly and lb7 and prefer my lb7 anyday.
jacobdewey is offline   Reply With Quote
Old 01-01-2013, 10:39 PM   eBay Motors  #13 (permalink)
FARMBOY26's Avatar
yes i have driven both plenty of times all of them stock the lbz seemed to be a little snappier but the lb7 didnt seem to be any different
Old 01-01-2013, 10:43 PM   eBay Motors  #14 (permalink)
jacobdewey's Avatar
Well maybe it's all preferance. Stock to stock my lly and lb7 were the same power, but my lb7 would kill my lly in economy and running cool. Best mpg out of lly was 17.2, best out of lb7 was 24 mpg. All hand calcualted, driving 55-60 mph.
Old 01-02-2013, 12:36 AM   eBay Motors  #15 (permalink)
1SLOMAX's Avatar
yeah you cant beat a lb7 when it comes to MPGs
2005 LLY CC/SB
Diesel Addiction Tuned
Built Trans
Lowered
Twentys
Street Tires
1SLOMAX is offline   Reply With Quote
Old 01-02-2013, 06:37 AM   eBay Motors  #16 (permalink)
Originally Posted by TubbedTruck67 View Post
Ill have to see wat cp3 was put on it but i knew the remans from a parts store came with a new one but figured that was probly extra at the dealer..
How do i do a leak test on the injectors?
This is how you do them at home:
http://www.dmaxcentral.com/forum/showthread.php?t=3206
Also do a bottle test to be sure the FPRV isn't leaking too.
That seems pretty consistent with what most have seen. Both the LB7 and LLY have the same compression ratio so if must be either the emissions equipment (EGR + Exhaust) or the turbo which is the difference maker. Can't imagine the PCV makes a huge dent in MPG. If anyone had any insight on that I'd be all ears.
MTL_Dmax is online now   Reply With Quote
