| Junior Member Join Date: Mar 2009 Location: OH
| 04.5 lly crazy balance rates this 04.5 lly is showing some crazy balance rates, white smoking, and has a rough idle/fuel knock. truck has about 90k miles on it, had injectors replaced couple months ago at a dealership. not sure what injectors they used. anyone think the injectors are the culpret? franklly.JPG
__________________ 06LLY 04.5 LLY |
| Senior Member Join Date: Jun 2011 Location: madison wi
| i dont know enough about them but i was reading on here that they are suppose to be +/- 4
__________________ 05 lly cc, afe turbo inlet, blocker plate, efi dsp5 by nick (duramaxtuner.com) |
| im aware of the tolorances +-4 i just wasnt sure if balance rates could go this high or if something else could cause these exact symptoms.
| Junior Member Join Date: Jun 2012 Location: On the land of the rising sun
| That does seem like injectors, could very well be a fuel pump or filter, not sure though. |
| Senior Member Join Date: Jan 2012 Location: edmond ok and nw ks
__________________ Curt 05 GMC ccsb slt 4x4 efi live 3"dp 5"straight pipe built trans airdog blocked rerouted lbz mp power steering 95 dodge eclb cummins 4x4 5sp slt 90 F-250 rclb 7.3 4x4 |
| Actually 13.8 all the way across, something wrong with that sensor? Sent from my iPhone using AutoGuide.com App
| | eBay Motors #7 (permalink) | |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| Quote:
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods | |
| Duramax Lifetime Supporter Join Date: Aug 2008 Location: Pueblo, Co
| Not an expert but I to am trying to learn. I thought you were to do the balance rate test when the engine is up to temp. If I am reading this correctly the engine temp is not anywhere near normal operating temp.
__________________ Clifford is a 2005 GMC Loaded SLT 2wd with; true cold air intake mods, ported LBZ turbo inlet mouthpiece, AFE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, Silverline 4" S/S exhaust, EGR Blocked, EFI Live DSP5 By Idaho Rob, Bully Dog pillar mounted outlook monitor, V2 radiator, thermostst controlled oil cooler, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BF Xenon 6000k Headlights Low & Hi, Air lift Remote control 5000# air bag system, Rear mounted under the bumper halogen lights, EZ down Tailgate assist, Put co S/S mud flaps, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors. |
| DuramaxForum Enthusiast Join Date: Jun 2011 Location: Bellingham, Wa
| Because you have a bunch adding fuel...pull out the compression testor before you do anything else
__________________ Gideon ![]() 01 LB7 EC/SB Ally 4x4 shop ornament DD: 1990 4runner completely stock 4x4 3.slow Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel |
