Blowing bulbs - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 01-03-2013, 12:47 PM Thread Starter
Question Blowing bulbs
I have a 2005 chevy duramax. The problem I'm having with it is that it's blowing the headlight and the fog light bulbs too fast.( at least once a month on the headlight and once every three months for the fog lights). A mechanic told me it sounds like that's from over charging, but when I took it to the shop to the alternator guy, he tested the alternator, and said the alternator was fine. I can feel the heat coming from the headlight from standing about one foot or more away from the headlight. Any suggestions would be greatly appreciated!
tonyo1242 is offline
post #2 of 5 (permalink) Old 01-03-2013, 12:59 PM
zeke38's Avatar
Send a message via AIM to zeke38
Mines the same.
Sent from my SPH-L710 using AutoGuide.Com Free App
2006 LBZ. ATS Stage 2 W/ Co-Pilot. EFI Live. 5" diamond eye. Keys. Tierod Sleeves. CenterLink. Gauges.
zeke38 is offline
post #3 of 5 (permalink) Old 01-03-2013, 01:37 PM
GMC..Professional Grade
KensAuto's Avatar
are the plugs melted or tarnished? a bad connection can cause to much heat. But other than that, it's usually voltage (to much) that kills them.......or really cheap bulbs.
2012 GMC 2500 SLT 4x4
---Arizona Diesel Club---
Member #19
KensAuto is offline
post #4 of 5 (permalink) Old 01-04-2013, 06:00 PM
gimpy's Avatar
Check your connectors for moisture or tarnished. Clean them then put white Lithium or electric grease on the connectors and see if that helps.
2004.5 LLY
S&B Intake
MBRP 4" Exhaust
Duramax Tuner EFI Live ECM
gimpy is offline
post #5 of 5 (permalink) Old 01-05-2013, 03:42 PM Thread Starter
Ok thanks
