| Life Time Supporter Join Date: Aug 2009 Location: Wichita Ks
| 04 LLY Idles fine,runs rough till warm Ok guys i have a 04 LLY with 5" exhaust.other than that,its stock with 150,000 miles. it starts right up and idles fine,put it in gear and take off and it starts surging and has no power.some times it may blow a little white smoke,in one instance it was blowing a lot of black smoke and clattering like the old Fords. never get a CEL during any of this. once its up to operating temp it runs flawless ! it started after i filled up so i naturally thought i had bad fuel. changed the filter,added a whole bottle of DK and a 16oz bottle of 2stroke with no change. my buddy has a cheap scanner that will tell me the DTC.s and fuel pressure but thats about it. No codes and the fuel pressure at idle is around 5500 and when driving it will go up to 19-21K. the new filter was from auto zone(house brand) since they were they only one left open late,but it is a 2 micron filter. I looked at the wiring at the alternater bracket a while back and someone had reaired it in the past and insulated it pretty good. I would think that if that was the problem it wouldn't clear up when the engine warms up?any thoughts ? Thanks Tom |
| Senior Member Join Date: Jun 2011 Location: Reno
| You need to ditch that filter for a GM/Racor Filter. And clean your MAF with the MAF cleaner spray. Then ice pick all your injector connectors. Check the harness that is ziptied to the alternator bracket. Insulate it with heater hose. If nothing changes id bet its injector(s). It was for me when i had the same issues Sent from my iPhone using AutoGuide.com Free App
__________________ 2004.5 Chevy CCSB LT2. Black, 6" tuff country ez ride. 35-12.50r16 Toyo MT. AMP Fourty one-2 wheels painted black. Bilstein 5100's. AMP research elec. steps. 4" MBRP Turbo Back w/5" tip. pcv re-route, modded air box, EFI Live! DSP5 powered by Edge insight CTS...EGR blocked. Viper remote start and alarm. Custom built bumper by CountryBoy2500, with 3000k HID's and Hella 500's. 5000k HID's in lows. Raptor lined rocker panels. Tinted to match and tow mirrors. Energy Suspension Poly bushings. 9 speaker J&L audio setup coming soon..NBS cab lights |
| | eBay Motors #3 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
X2 Follow the list above ^^^^^^ and you will find your issue.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
