Block heater and EGT - Chevy and GMC Duramax Diesel Forum
Old 01-13-2013, 02:10 AM   eBay Motors  #1 (permalink)
wfobogger's Avatar
I've tried searching and I'm not sure if my searching skills are just sub par or what, but I've got two questions
Where does everyone's plug for their truck located at? Mine is just laying under the hood with no destination
Second I'm curious what everyone's idle EGT temps are, I'm new to a diesel and I heard I was suppose to wait for them to lower before I shut down? Also what's high range for EGT?
2005 Chevy 2500HD Extended Cab Long Bed
AFE LLY Mouthpiece
4inch turbo back exhaust
Edge Juice with Attitude
Leveling kit
wfobogger is offline   Reply With Quote
Old 01-13-2013, 02:21 AM   eBay Motors  #2 (permalink)
wfobogger's Avatar
I guess the reason I'm asking is my friend says his idles at 220-260 mine idles at 330-360 I can set my edge juice to alarm at a certain temp also but I'm not sure what the temperature should be....
AFE LLY Mouthpiece
Leveling kit
Old 01-13-2013, 03:15 AM   eBay Motors  #3 (permalink)
JUST TROLLING AROUND
vinnie gillotti's Avatar
your egt's are fine the cords are very short i put a heavyduty3ft ex cord on mine run it out the bumper.
05 lly 2500hd ccsb http://s1135.photobucket.com/albums/m635/vinnie_1965/
vinnie gillotti is offline   Reply With Quote
Old 01-13-2013, 11:59 AM   eBay Motors  #4 (permalink)
wfobogger's Avatar
I kept trying to run it out the bumper area but no way it was going to reach
Is it true that I should wait for my EGT to drop down before shutting down the truck? And what's high range for EGT so I can set my edge correctly
AFE LLY Mouthpiece
Leveling kit
Old 01-13-2013, 12:10 PM   eBay Motors  #5 (permalink)
boostnlb7's Avatar
my cord is wrapped around the core support and i poked it out between my headlight and my grille.. and your egt's idling are fine.. you dont wanna see sustained 1400's..you will see over 1000 when standing on it with that edge.. but if u start climbing up to 1300 i would ease out of the skinny pedal
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 01-13-2013, 12:26 PM   eBay Motors  #6 (permalink)
DAMMIT Another Upgrade
dhaynie's Avatar
The cord is wrapped in the loom it was attached to. If you undue the wire loom you can pull enough cord out to reach the bumper.
2006 LLZ 2500HD CCSB, Diablosport Predator, PCV Reroute, EGR Block, Finger Stick, LT3, Summit White
dhaynie is offline   Reply With Quote
Old 01-13-2013, 02:37 PM   eBay Motors  #7 (permalink)
wfobogger's Avatar
I did see that the cord went into the loom and wasn't long enough, ill try n undo the loom and get it to reach thanks!!
AFE LLY Mouthpiece
Leveling kit
Old 01-14-2013, 06:23 PM   eBay Motors  #8 (permalink)
boostnlb7's Avatar
i thought u were asking where we have ours located, like you couldnt find a good place for yours.... btw its connected to the block heater
Old 01-14-2013, 06:32 PM   eBay Motors  #9 (permalink)
wfobogger's Avatar
Yeah I didn't know if you had it coming out like your grill or your tow hooks or under your fender and so on, mine only seems like it would reach out my fender
AFE LLY Mouthpiece
Leveling kit
Old 01-16-2013, 12:42 AM   eBay Motors  #10 (permalink)
KB3MMX's Avatar
It's a good idea to idle briefly before shutdown to extend turbo life. If you can get EGT to 300F or less, that's great.
One trick is to shut off the AC or Defroster when idling, it'll take some load off the motor and cool faster.
With proper timing, it should idle down to 240-280F.
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
