My LLY injector balance rates - Chevy and GMC Duramax Diesel Forum
Old 01-16-2013, 02:21 PM   eBay Motors  #1 (permalink)
Vtduramax's Avatar
Just picked up a edge cts today and checked my balance rates. Truck has 75k on it. Number 8 seems a little high but still in a safe range?
GMC 2005 LLY
DSP2 Duramax Tunner
Egr blocked pcv re reroute Air Dog 2 100
Edge cts AFE blade runner
4 inch MBRP turbo back 5 inch tip
4.5 inch pure performance lift w/pure performance 2.0 custom valved shocks.
Sleeves and pitman/idler arm braces
33 inch toyo mts on 17 inch XD misfits
Recon cab lights
Vtduramax is offline   Reply With Quote
Old 01-16-2013, 02:26 PM   eBay Motors  #2 (permalink)
boostnlb7's Avatar
your golden!!! no high numbers there.. was that in park or drive?
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
Old 01-16-2013, 02:34 PM   eBay Motors  #3 (permalink)
Vtduramax's Avatar
It was in park. I did see number 8 go up to 5 at one point. I shut the truck off and then got this reading I took a pic of. Not sure why it went down just from restaring my truck.
GMC 2005 LLY
DSP2 Duramax Tunner
Recon cab lights
Old 01-16-2013, 02:38 PM   eBay Motors  #4 (permalink)
boostnlb7's Avatar
thats wierd.. a 5 is a little outta spec but from the pic your just fine.. see what they do when u put it in drive with the brake down
Old 01-16-2013, 03:26 PM   eBay Motors  #5 (permalink)
Vtduramax's Avatar
So these are the numbers in ImageUploadedByAG Free1358378520.040976.jpgdrive. Did see 8 go up to 5 at one point. Injector 5 also went up to around 4.5. From searching around the forum, it seems the first place I should look is the wire harness that rubs on the alternator? I guess that can throw weird numbers if its chafed?
GMC 2005 LLY
DSP2 Duramax Tunner
Recon cab lights
Old 01-16-2013, 03:29 PM   eBay Motors  #6 (permalink)
boostnlb7's Avatar
yes it will... that will be a good start.. to bad they all look like 1 and 4
Old 01-16-2013, 03:40 PM   eBay Motors  #7 (permalink)
Vtduramax's Avatar
Alright thanks. Now injectors 5 and 8 are both reading 1 haha. Will let you know how that harness looks when I check it tomorrow.
GMC 2005 LLY
DSP2 Duramax Tunner
Recon cab lights
Old 01-16-2013, 04:34 PM   eBay Motors  #8 (permalink)
boostnlb7's Avatar
Thats wierd.. I dont think they should move like that
Old 01-19-2013, 02:13 PM   eBay Motors  #9 (permalink)
Any ideas?
image.jpg these arent in spec but seem to bounce around a lot. Any ideas as to why. I ran injector cleaner through it to see if it would help.
05 CC/SB 4 wheel peelEFI live from Duramaxtuner.com edge insite CTS 4" MBRp turbo back with down pipe ,
LEFT TO ISTALL: lbz intake elbows, afe stage 2 intake, egr blocker plate
ArmyBlouvet08 is offline   Reply With Quote
Old 01-19-2013, 02:14 PM   eBay Motors  #10 (permalink)
Before
