fuel mileage - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 02-10-2013, 10:51 AM Thread Starter
fuel mileage
Looking at a used 2005 duramax has 176k on it. Wondered who has actual fuel mileage? I had a 2001 and got near 20 mpg empty and about 14 towing 6,500. Any advice would be appreciated as well as any pitfalls to look for i thins year.
any input on its value is cool too.
keith gigabyte is offline
post #2 of 8 (permalink) Old 02-10-2013, 11:14 AM
Your MPG will be a bit less than an LB7 because of the vvt turbo and emissions equipment but I still see 18-19 MPG highway unloaded.
MTL_Dmax is offline
post #3 of 8 (permalink) Old 02-10-2013, 11:18 AM
calewjohnson's Avatar
My only mod is an AFE mouthpiece...I see 18-19mpg (hand calculated) empty and 11.5mpg when towing (7500lbs). I generally drive no faster than 65mpg, I am never in a hurry....
Cale
2005 2500HD CC, D/A, 4x4, AFE Mouthpiece, EFI Live by Kory Willis controlled by Edge Insight CTS, Rancho 9000XLS all around, EGR Block, Turbo Resonator, MBRP CAT Delete, AirDog II 165, PacBrake Air Bags
Waiting to be done: 52 gallon Titan Fuel Tank (on the fence)
calewjohnson is offline
post #4 of 8 (permalink) Old 02-10-2013, 11:36 AM
nick45l's Avatar
I get 17-18 in the summer, 15-17 in the winter. If I let it warm up often it might go as low as 14. Mostly hwy and 60 mph or less.
2004 GMC 2500 4x4 CCSB LLY swapped. EFI Live by Kory, AFE Bladeruner MP and stage 2 CAI, Magnaflow DP and 5" exhaust, M/A mounts
My LLY swap thread
nick45l is offline
post #5 of 8 (permalink) Old 02-10-2013, 07:35 PM Thread Starter
mtl..you have to let me know what the vvt turbo is..im still new to diesels..
thanks,
ketih
post #6 of 8 (permalink) Old 02-11-2013, 10:26 AM
Flat ground at 70MPH empty I get 19. Towing 11k at 60 I get 11-12. I am stock other than the mods below. The truck weighs 7150lbs with a full tank.
2005 Chevy Silverado 3500LT SRW D/A CC/LB LLY 4x4 (loaded)
LBZ MP, TxCAI, PS Cooler, stack seal, Edge Insight CTS + EGT + EOT, E837 HD Radiator + Aux Radiator w/fan, Earl's trans cooler, mass/IAT shield, LML manifold, SD rotors
NuWa Hitchhiker II LS 29.5LKTG 5th Wheel
terryk is offline
post #7 of 8 (permalink) Old 02-11-2013, 10:36 AM
Ragin Cajun's Avatar
Before tuner but with other mods listed in my sig:
18mpg unloaded cruising 70mph
16mpg unloaded city
10-11mpg towing 12K fifth wheel cruising 60mph
Great truck...
2005 Chevy LT CC 2WD SRW SWB 6.6L LLY
EFI Live DSP2 by DuramaxTuner
Stage 3 Trans by Diesel Addiction (NC)
AFE Mouthpiece / K&N CAI / Pro Fab 3" Downpipe
4" Exhaust Straightpipe w/5" MBRP Tip
16x8 XD Hoss Wheels on 265/75/16 BFG's
Bilstein 5100's / Firestone Ride-Rite Airbags
Pullrite Superglide 15K
Stanadyne PF
150K plus miles & counting
Ragin Cajun is offline
post #8 of 8 (permalink) Old 02-18-2013, 10:27 PM
Hey im looking at buying a 2005 ccsb with 87000 miles. The guy just has juice with attitude and the cats taken out and a k&n intake. 6 inch lift and 35 inch tires and claims he gets 13 city and is not sure about highway. Is this true and what will my highway be roughly? Would efi live and exhaust help much?
Neyens is offline
