head gasket replacement - Chevy and GMC Duramax Diesel Forum
post #1 of 64 (permalink) Old 01-22-2009, 07:45 PM Thread Starter
Post head gasket replacement
Whats the best way to perform head gasket replacement,ya I know have the dealer do it but I have seen it done several ways.Removing the trans to access the rear of the turbo even removing the body lifting it up off the frame saves on the back to removing the engine. Has anybody done this and thinks one way is better than the other?You got to love GM si just take the bolts out and your done that easy.
ffunaro is offline
post #2 of 64 (permalink) Old 01-22-2009, 09:01 PM
Super Moderator
BigRedChevy's Avatar
The dealer did mine with the engine in, tranny in, and body on. They took everything right out the top.
BigRedChevy is offline
post #3 of 64 (permalink) Old 01-22-2009, 09:10 PM
We do them all with the body and front end still on. If we are going to do an engine we remove the body. Their is no easy way to do head gaskets. You have to do both sides at the same time. The book time on this is 34.8 hours. Its a complete pain in the ass and SHOULD NOT be peroformed by someone who has any doubts about doing it. Their is lots that can go wrong. You also need to remove the heads and then order the gaskets as per the thicknesses. They are different side to side and their is 3 different options.
2017 L5P CCLB DRW LBZ
2015 LML sold
2014 LML sold
2005 LLY sold
Toypuller is offline
post #4 of 64 (permalink) Old 01-22-2009, 09:14 PM
duramaxxin73's Avatar
I've done one, and left the cab on. I don't know how much easier it would be to take the cab off. I know on the 6.0's if you want to get the job done quick its best to take the cab off.
2004.5 Chevy Silverado (J.T.) 2500HD "Dirt Nasty" LLY
Currently under construction for ODL
EFI Live Tuned By Mark Broviak @ Danville Performance
Danville Performance Specializing in GM Performance including Duramax Diesels from stock to Full out competition trucks. Custom EFILive tuning, In house Dynojet 224LC Dyno, Custom Danville Performance Turbos including VGT's, Modded LBZ CP3's, Sled pulling setup and parts, competition built motors, etc... For more details Call Larry, Matt, or Mark at 317-745-8587
www.DanvillePerformance.com
duramaxxin73 is offline
post #5 of 64 (permalink) Old 01-22-2009, 09:34 PM
It would make it way easier to do after you get the cab off. But how many people can actually pull of the cab. Almost none.
2015 LML sold
2014 LML sold
2005 LLY sold
post #6 of 64 (permalink) Old 01-23-2009, 05:45 AM
Diesel Addict
its way easier taking 12-15 bolts out and removing the front clip..we did our Headgaskets in 14hrs and we had never done it before..its very straight forward just pull everything off and remember where it came from..
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline
post #7 of 64 (permalink) Old 02-17-2010, 03:43 PM
lb7duramax's Avatar
what are you getting at taking the front clip off?? looking to do mine since labor is $2500 alone. did you really do yours in 14hrs? any tips or things that make it easyer and quicker??
thanks alot
2002 chevy 2500hd crewcab long box
six inch lift, w/ 35's, edge juice cs w/ EFI
4" MBRP turbo back, S&B intake, BD manifold
Fass Fuel Pump, ARP studs grade C gaskets
ranch hand bumpers and headache rack built by me and line x
recon smoked cab lights, tow mirrors
Cognito pitman, idler supports, HD tie rods, and spicer Pitman/idler arms
zf6 swap
lb7duramax is offline
post #8 of 64 (permalink) Old 02-17-2010, 07:30 PM
Siewell Dmax's Avatar
Just finished my LB7. Gaskets all around and cups, did not take the turbo out just took the intake crossover out. Patience and decent tool box will get you through it.
(FOR SALE) 2004 Silverado 2500 HD, LB7, Resonator capped, shiny mod's - billet door handles and buckets, Centerline Blackfoot forged wheels, and a drop in K&N filter. New Headgaskets, Injectors, Cups, Turbo and Nicktane Cat Filter mod. ****(AND IT IS FOR SALE)****
Siewell Dmax is offline
post #9 of 64 (permalink) Old 02-17-2010, 07:47 PM
I am in the middle of doing mine & i was thinking that i should have taken the trans out, those up pipe bolts are a PITA & there is not much room on the drivers side to do anything.
New Truck
2006 LBZ CC/SB
Full Built Motor
Dual Fuelers,100%exergy sticks
AirDog 200 Pump
Twins 66/88
Tuned by ATP (Rob)
Caltracs
and a bunch of other stuff:
bmos37 is offline
post #10 of 64 (permalink) Old 02-17-2010, 08:07 PM
lb7duramax's Avatar
just started mine this afternoon im hopeing its not to big of a PITA. does anyone know what the torque specs are on all the inportant bolts???
BMOS37
You said you blocked off your EGR what is there to that?
zf6 swap
