Fuel Leak - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 05-23-2013, 02:11 PM Thread Starter
Fuel Leak
Hey Guys i have a fuel leak on my 2005 LLY LS...it looks like there is a radiator for the fuel under the driverside backseat...what is that called and is it an expensive fix or am i just that clueless when it comes to this...Thanks Guys im sure someone can help me
DuraBomb is offline
post #2 of 6 (permalink) Old 05-23-2013, 03:10 PM
The S.O.M.'s Avatar
That would be the fuel cooler, Could you possibly post up a pic of the leak so we could get a better idea of where it's originating from in that area?
2004.5 LLY ECSB 4X4
EFI Live
Danville Stg2r
Bosch Motorsport 65% overs
MA700 Trans
Lots of HSP Diesel parts!
ARP Studs
Built Front End
The S.O.M. is offline
post #3 of 6 (permalink) Old 05-23-2013, 03:26 PM
Administrator
jc1843's Avatar
Yes, fuel cooler-- it cools the un-used fuel as it goes back to the fuel tank. The common problem in the rust belt. Salt, snow and ice will rust the fitting and lines. [brake lines also]
jc1843 is offline
post #4 of 6 (permalink) Old 05-23-2013, 04:50 PM Thread Starter
Thats exactly what happened jc1843...do you know if it is an expensive fix?...or easy?
DuraBomb is offline
post #5 of 6 (permalink) Old 05-24-2013, 07:50 AM
Administrator
jc1843's Avatar
Dont know what it costs, but the damn lines are big bucks from the dealer-. I would fab up some hoses-- if you can find fittings to the cooler. There is low pressure, so regular gas 3/8 hose should be OK.
Not recommend you by-pass the cooler.
jc1843 is offline
post #6 of 6 (permalink) Old 05-24-2013, 08:12 AM
X2
Same happened to me. Don't bypass it, assuming the cooler is good just fix it with some brass hose fittings (on cooler), quality fuel line and some stainless hose clamps. Use a dremel tool to cut off the metal compression fittings towards the front and attach your fuel line there. Insulate any places the hose may rub on frame/brackets/etc and zip tie well.
MTL_Dmax is offline
