What are signs of a bad alternator? - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 02-21-2009, 04:30 PM Thread Starter
Newman1415's Avatar
Im not 100% sure, but my new Dmax compared to my old one has this deep whining sound that goes with the rpm of the engine, to me it sounds like an alternator, i remember that sound from one of my old 1500 gassers. My old dmax never made this sound. Its very inoying, its not the turbo i know that sound. the voltage is over 14, any ideas? Also i havent had a chance to use the A/C yet. could it be that making the noise if it was bad?
2005 LLY Silverado 2500HD Crewcab LT
5" MBRP Turbo back with Downpipe
Cobalt Pyro & Boost
LBZ MP - EGR Blocked
DSP 5 EFI
6" Zone lift
17" KMC Addicts
35" Nitto Trail Grapplers
www.alligatorperformance.com
Newman1415 is offline
post #2 of 8 (permalink) Old 02-21-2009, 04:33 PM
the lawn man
coles220's Avatar
well if its still charging it doesn't sound like an alternator mabey thetensioner going bad could be my thought
2008 3500HD Dually SLT
raptor 150 lift pump
efi live dsp 5
edge insight to watch everything
egr blocked and pcv reroute
cognito tie rods Stage IV Tranny kit
www.meyerperformance.com
coles220 is offline
post #3 of 8 (permalink) Old 02-21-2009, 04:36 PM
smog's Avatar
it could be your alt bearing going out. but also check the idler pully and ten. they sould just like bad alt bearing.
if you can take off the serp belt and spin the pully by hand if they are really bad you could here it. ( not all the time )
2006 CCSB LLY ZF-6
CAT DELETED
SECONDARY FUEL FILTER
EGR BLOCKED AND FINGERED
PPE AIR BOX MOD
PCV RE-ROUTED
EDGE RACE
03 GMC STEPSIDE (FOR SALE)
smog is offline
post #4 of 8 (permalink) Old 02-21-2009, 05:02 PM
Slave to the Interwebs
Johnasara's Avatar
Possibly tensioner.They wear out pretty quick
Johnasara is offline
post #5 of 8 (permalink) Old 02-21-2009, 09:35 PM
Tow Master's Avatar
Ya Id slip the belt off and check. The alternator and tensioner pulley should spin freely without mutch resistance if any.
To check the a/c compressor just turn it on and see if the noise gets better or worse.
Jason
Tow Master is offline
post #6 of 8 (permalink) Old 02-21-2009, 09:38 PM
blackdeath's Avatar
yeah take the belt off spin the pulleys by hand to hear the noisy one, <<<< yeah dont try to spin the crank >>> lol j/k
blackdeath is offline
post #7 of 8 (permalink) Old 02-21-2009, 10:45 PM Thread Starter
Newman1415's Avatar
where is the tensioner located? I will check these things this week
Cobalt Pyro & Boost
DSP 5 EFI
6" Zone lift
17" KMC Addicts
post #8 of 8 (permalink) Old 02-21-2009, 10:50 PM
Tow Master's Avatar
I forget exactly where butits the pully thats not connected to anything. Thats usually how you remove the belt. Gotta get a 1/2 drive ratchet and push on it. Then remove the belt.
Jason
