Coolant leak - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 08-22-2013, 06:19 PM Thread Starter
05dmax89's Avatar
Coolant leak
I haven even messed with my driver side at all now all of a sudden have a same drip I can't see nothing from the top and only can see it right above the filter and thts it I can't find the source of the leak any where
2005 LLY
AFE intake/6" procomp lift/extra rearleaf spring/4" straight pipe to 5" tip/35x12.50x17 Mickey Thompson MTZ /procomp wheels/airdog 150/lbz mp/pcv reroute/big air kit/sulastic shackles/ bilsteins 5100/reacon interior lights/frontier bullnose bumper/ lml manifold/kryptonite control arms/stage 2 frontend/efi by kory/edge insight/gmax 5 wit precision tc/cat adapter filter
92 12 valve
4 in diamond eye/he 351cw/nv 4500
05dmax89 is offline
post #2 of 9 (permalink) Old 08-22-2013, 06:22 PM
Thebiggids's Avatar
Use mirrors...and look around
GideonHeyyaa
01 LB7 EC/SB Ally 4x4
DD: 1990 4runner completely stock 4x4 3.slow
2007 Yukon Denali - Hers
Big Thanks To Adrenaline Truck Performance, Alligator Diesel PerformanceSocal Diesel and Lincoln Diesel Specialties
Thebiggids is offline
post #3 of 9 (permalink) Old 08-22-2013, 06:22 PM
SnafuPossum's Avatar
You say driver side so I assume the filter being the oil filter? Check the tube that comes off the water pump, its the easiest thing to check, motor may need tk be on and at temp to see the leak?
~Ross~24~
2004 LB7 2500HD ccsb: 5in exhaust, cognito upper control arms, rare parts tie rods, cai, appradio2
Originally Posted by Varty Yo View Post
My buddy had a roomba and his dog had shit on the carpet. Well the freaking thing mashed gooey shit all over the room all day long while the dog hid in the corner
SnafuPossum is offline
post #4 of 9 (permalink) Old 08-22-2013, 06:29 PM
tmm403's Avatar
If it by the oil filter....it could be your oil cooler coolant gasket.
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids.
tmm403 is offline
post #5 of 9 (permalink) Old 08-22-2013, 06:34 PM Thread Starter
05dmax89's Avatar
Yes the oil filter I'm not sure i think I saw it a little higher than it
Like I said i can see nada from the top ill have to look again tomorrow
05dmax89 is offline
post #6 of 9 (permalink) Old 08-22-2013, 06:37 PM
Thebiggids's Avatar
Could be leaking in a lot of places and running down the back of the motor.
There's coolant lines to the turbo, in the valley of the engine that could be leaking. Best bet would get some mirrors and some kind of pressure kit to put the coolant system under pressure to look for leaks
GideonHeyyaa
post #7 of 9 (permalink) Old 08-22-2013, 07:20 PM Thread Starter
05dmax89's Avatar
One more thing I noticed was the rubber hose connected to my raidtor to my thermostat was like flat like there was suction on it
2005 LLY
92 12 valve
05dmax89 is offline
post #8 of 9 (permalink) Old 08-22-2013, 09:03 PM
its suppose to do that on a cold truck.
~Ross~24~
post #9 of 9 (permalink) Old 08-22-2013, 09:05 PM Thread Starter
05dmax89's Avatar
I never noticed tht
2005 LLY
92 12 valve
05dmax89 is offline
