| | eBay Motors #21 (permalink) |
| Junior Member Join Date: Apr 2012 Location: Illinois
| Try searching "frame beaming." Look at the lower body lines between the cab and the front of the bed if they aren't lined-up the the rear body mount is toast!
__________________ 05 CCSB 4x4 GMC "Missing" Kitty, Blocked EGR, full LBZ intake EFI live Compliments of Idaho Rob |
| Junior Member Join Date: Aug 2012
| Hmm.... Well after going through the entire front end and everything is tight as it should be, maybe it is the frame beaming. Crazy as the mount doesn't look bad. I did notice a lot of weights were used for these new tires as well....
__________________ 2007 Silverado 2500HD Classic LT3 LBZ Crew Cab 4x4 6.6L 6-Speed Banks CAI, Diamond Eye 5" DPB exhaust Ready Lift Leveling kit 20" Ultra wheels and 35x12.5-20 TOYO M/T EFI Live by Idaho Rob and EGR Delete ![]() |
| | eBay Motors #23 (permalink) |
| DuramaxForum n00b Join Date: Apr 2010 Location: Virginia Beach
| I had the same issue with my truck about two months ago and it was a combination of the ride hight and the tires were not balanced correctly.
__________________ 2003 GMC LB7 Banks Big Head MBRP IC Pipe MBRP 4" Exhaust 85HP Predator Tune BD Exhaust Manifold Boost and Pyro Guages S&B DRY Filter AD II 165 |
| DuramaxForum Veteran Join Date: May 2011 Location: Regina, Sask!
| Its frame beaming! Try new cab mounts!!!
__________________ 2006 LBZ Mike L Stage Awesome! Airdog2 165, 5" MBRP Turbo back EFI Live tuned by Idaho Rob, DSP5, ATP Cognito set at 8" Nor-cal Truck SS idler support/ Rare parts tie rods 37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes HID's All on mod/ AMP reaserch steps |
| Read through the "frame beaming" page and there was about 6 different part numbers for the new mounts. Anybody have a better number for it? Gmpartsdirect is a hard site to search for stuff. Thanks
| GM Campaign #PIT3009J: Suspension Vibration Or Frame Beaming At 40-60 MPH (64-80KM/H) - keywords front rear shake shock spring tire - (Sept 18,2008)"" Condition/Concern: Beam shake vibration is usually felt and occurring at speeds between 40-50 mph (64-80 km/h). Hertz readings using an EVA tool are normally bewtween 8-24 HZ. This condition is most common on extended cab and crew cab models but has also been noted in other models. Recommendation/Instructions: The severity of the beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following: 1. Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible. 2. Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate. ----------- If the concern is determined to be beam shake, this a characteristic of the vehicle. GM Engineering has released updated body mounts to reduce this concern for the Crew and Extended Cab Models. There will be no changes made to the Regular Cab Models. FOR CREW AND EXTENDED CAB MODELS, REPLACE THE REAR CAB MOUNTS WITH UPDATED PARTS LISTED BELOW. THESE PARTS SHOULD NOT BE USED ON REGULAR CAB MODELS. New upper and lower mounts should be installed at the left and right rear cab position. The new LOWER mount is a two-piece design, meaning there is a rubber mount with a metal washer. Some models may use a one piece lower mount, meaning the rubber mount has a metal washer molded into it. If the vehicle has the one-piece lower mount design, washers (PN 15854745, Qty 2) will be needed to be used with the new lower mount. Upper Mount 25791031 Qty 2 Lower Mount 25791032 Qty 2 Washer 15854745 Qty 2 (if needed) Please follow this diagnostic or repair process thoroughly and ccomplete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
| | eBay Motors #27 (permalink) |
| Senior Member Join Date: Jun 2011 Location: Reno
__________________ 2004.5 Chevy CCSB LT2. Black, 6" tuff country ez ride. 35-12.50r16 Toyo MT. AMP Fourty one-2 wheels painted black. Bilstein 5100's. AMP research elec. steps. 4" MBRP Turbo Back w/5" tip. pcv re-route, modded air box, EFI Live! DSP5 powered by Edge insight CTS...EGR blocked. Viper remote start and alarm. Custom built bumper by CountryBoy2500, with 3000k HID's and Hella 500's. 5000k HID's in lows. Raptor lined rocker panels. Tinted to match and tow mirrors. Energy Suspension Poly bushings. 9 speaker J&L audio setup coming soon..NBS cab lights |
| | eBay Motors #28 (permalink) |
| Bransjeep, how do you like the poly bushings? Are they stiffer or still give a good ride? It's gonna cost about the same to get the new rear bushings vs all 6 poly's from what I've seen
| | eBay Motors #29 (permalink) |
| Senior Member Join Date: Apr 2010 Location: Hagerstown, MD
| I had the same exact problem and it was solved by having the tires road force balanced. I had tried several times on our shop balancer and it wouldn't go away. Took it to a place that does roadforce balancing and it rides like a car now!
__________________ Kervin. 21. A.S.E certified master-tech. 2004 LB7ccsb 4x4: Performance: Idaho-rob dsp-5, S366 from EPR, head studs, airdog 150, Dmax4 trans, gauges, tie rod sleeves, intake, exhaust. Looks: Colormatched 06 front clip and tow mirrors, tinted out + 45% on windshield + 12" banner, hids, 325 fierce attitudes, etc. Interior: Leather, 1500 watt rms sub system, blue led interior lights, Nuspeed dash insert. |
| | eBay Motors #30 (permalink) |
| I looked that up and the shop I went to is supposed to have that kind of balancing. I'll have them rebalance and if that doesn't work.... Body mounts
