Replacing fuel injection pump - Chevy and GMC Duramax Diesel Forum
post #1 of 22 (permalink) Old 05-11-2009, 09:38 PM Thread Starter
shades's Avatar
How hard is this? What parts am I going to need? Any special tools etc? Anyone know where I can find a write-up on this? Is it even worth me doing it versus having someone else do it?
Any help would be awesome!!!
Thanks for anything,
Geoff
2004 LB7 CC/SB (Bastard dont run... gettin the pretty girl fixed tho)
Turbo Resonator Plugged
4" straight pipe
shades is offline
post #2 of 22 (permalink) Old 05-11-2009, 09:48 PM
dmaxd2500's Avatar
It's about an 8 hour job for an experienced tech. In my professional opinion, I would have someone experienced do it if you have any doubts. Why are you replacing it?
08 GMC 3500 Dually "Moby Dick"
dmaxd2500 is offline
post #3 of 22 (permalink) Old 05-12-2009, 06:35 AM Thread Starter
shades's Avatar
Truck wont run. dealership wants 2gs to get it done. Just trying to find out my options I suppose.
4" straight pipe
shades is offline
post #4 of 22 (permalink) Old 05-12-2009, 06:46 AM
Trprowen's Avatar
Send a message via Yahoo to Trprowen
my local small time mechanic took 4 hrs to change mine and with parts and labor i ate 750 for it ... my stealership wanted over 2200 the part they told me was 1400...funny how i found the same part for alot less ... check around man !
2007.5 GMC 2500HD Crew Cab DURAMAX
MODS - EGR Blocker Plate, 5" Flo~Pro No Muffler Exhaust, DPF Delete, EFI, DSP5 Switch, TransGo JR. Tuned by Idaho Rob
OIF III VETERAN
US ARMY RETIRED
Trprowen is offline
post #5 of 22 (permalink) Old 05-12-2009, 12:39 PM
SDP
Scott@SDP's Avatar
Its not hard, took me 7hrs and it was my first time. You wont need anything as far as special tools that are too uncommon. IMO I'd rather spend the money on special tools that I could keep rather than pay 8hrs labor. You'll need basic tools other than a spanner wrench of some sort for the fan clutch pulley, fuel line disconnect tool, and a 3 prong puller of some sort to take the gear off of the pump once you get it out or you could take it to a shop to have it done real quick.
If you need any help you can just PM me and I'd be glad to help you out.
Screamin Diesel Performance 360-417-9000 Scott@SDPtwins.com
Compound twin turbo kits with 3" y-bridge and coolant tank for all Duramax's
SDPtwins.com LIKE US ON FACEBOOK!
2016 2.8L Duramax Canyon with SDP Compound twin turbo kit and DSP4 tuning
2009 LMM SDP trans, SDP GT5541/GTX42 twins, 200% injectors, 2x Exergy CP3's, Socal motor, ATP tuned
2002 LB7 SDP twins, ATP tuned, stock motor 11.97@113mph 7,200lbs
2001 LB7 SDP Built transmission, Single SDP S475, ATP tuning
2006 LBZ Race truck build
Scott@SDP is offline
post #6 of 22 (permalink) Old 05-12-2009, 12:46 PM Thread Starter
shades's Avatar
is there anything electronic that needs fixing along with this, i.e. reflash, relearn, etc... dont know the electronics at all...
4" straight pipe
shades is offline
post #7 of 22 (permalink) Old 05-12-2009, 12:47 PM Thread Starter
shades's Avatar
and why did you go with the LBZ pump? better, easier, cheaper?
4" straight pipe
shades is offline
post #8 of 22 (permalink) Old 05-12-2009, 12:47 PM
dmaxd2500's Avatar
You're right, it can be done faster, I'm just sayin 8 hrs is what most shops will charge. It all depends on if you have the time and basic know-how to do it. If you feel you can handle it then by all means dig in. I too can help answer Q's if you have em. It's not really a hard job, just a lot of stuff to take off to get to it.
post #9 of 22 (permalink) Old 05-12-2009, 12:59 PM
SDP
Scott@SDP's Avatar
It has a larger stroke volume so it is capable of putting out more fuel, you'll need custom tuning for idle because of the LBZ regulator unless you stick with an LB7 regulator and use the LBZ pump. I used EFI live to tune it so that it would idle correctly. Price was the same and externally the pump appears the same other than the regulator with uses the same plug in.
post #10 of 22 (permalink) Old 05-12-2009, 07:54 PM
I can do one in under 3 hours. Disconnect the batterys and start tearing her down. Its not that bad just nuts and bolts. Just keep groups of bolts together when taking it apart.
2014 CCLB SRW, Edge CTS EVO
Toypuller is offline
