Old 07-17-2009, 11:00 AM   eBay Motors   #11 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Good Work, nice graph. It really puts things in perspective as to why you can't pull the hills at less than 230.
Originally Posted by techinny View Post
…I think that is the easiest to read explanation of this whole mouth piece ordeal yet! Takes the guess work right out of the equation. Nice job!
Unless you’re color blind…:tease
Originally Posted by Skyhighsami View Post
I ported mine the other day, I am considering buying the LBZ piece though.
The added flow bench data with the modded MP would be interesting to see in comparison too.
Originally Posted by camdoc View Post
I was also suprised that an air filter with less than 17,000 miles was showing restriction.
What was the air box indicator showing? Anywhere near being correct?
Old 07-17-2009, 11:04 AM   eBay Motors   #12 (permalink)
RedBowTies88
RedBowTies88's Avatar
great post and welcome man x1000000 on this being sticky
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 07-17-2009, 11:19 AM   eBay Motors   #13 (permalink)
Warlord
Warlord's Avatar
Great post man. Thanks again for another great contribution to an already strongly supported topic.
2005 Chevy 2500HD Crewcab 4x4 LLY
4" MBRP Turbo back
LBZ Mouthpiece and intake resonator plugged
Predator Programmer set for 45hp 100ft/lbs (tow)
B&W turnover ball
Warlord is offline   Reply With Quote
Old 07-17-2009, 02:02 PM   eBay Motors   #14 (permalink)
camdoc
The air filter only had a couple of inches of water additional restriction. The Donaldson indicator doesn't trip until around 20-25 Inches of water, my filter wasn't that dirty. 25 In-H2O is almost 1 psig, that will certainly kill some power.
camdoc is offline   Reply With Quote
Old 07-17-2009, 03:15 PM   eBay Motors   #15 (permalink)
Paccool
Great data. What a huge difference in airflows!
Question - can you get a KB modified 05 mouthpiece comparison with the LBZ one? I hope the modified 05 flow is up close to the LBZ, that's what I have in my truck.
Thanks again for the info.
Stan
2005 Chevy Silverado 4x4, 285-70-17's on Hummer wheels. 24,000 miles. Banks Ram Air inlet system. Predator programmer, KillerBee modified mouth piece.
93 Dodge D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust,modified tranny,EGT/boost/tranny/tach gauges.Rear sway bar.Single stage Water/Meth system installed. Oversized intercooler
Paccool is offline   Reply With Quote
Old 07-17-2009, 03:25 PM   eBay Motors   #16 (permalink)
camdoc
If someone wants to loan me one to test I'll be happy to flow it and add it to the data.
Old 07-17-2009, 04:01 PM   eBay Motors   #17 (permalink)
1953drtelco
1953drtelco's Avatar
I agree with this being a great post....After buying my Duramax a couple of months ago I found this site and realized within a few hours the LLY MP was junk. I did upgrade and noticed quite a bit of difference. Since then I've added a TCAI from Killer Bee. Not only does the truck run better, but the fan hardly engages even when towing....
2005 HD2500 Silverado 60K miles
LBZ mouthpiece upgrade
TCAI from Killer Bee Custom Tune (ECM) awaiting extra cash
New Exhaust minus Cat (4") will be installed once I have a new ECM programmed (Tow/Mileage Tune)
1953drtelco is offline   Reply With Quote
Old 07-19-2009, 04:58 PM   eBay Motors   #18 (permalink)
anfo
is the orange line "LBZ/LLY modified" system the one killerbee makes or some other setup? and is the blue one (stock LBZ) that goes higher the best or, the orange one that goes second highest but over the higher test pressures better? I bought my truck last week and plan to buy whichever MP setup is better this week so ignore any stupidity, still learning the dmax ins 'n outs.
2005 CC/SB Duramax/Allison
4" Magnaflow stainless
LBZ MP Mod
Pyro & Boost gauges
anfo is offline   Reply With Quote
Old 07-19-2009, 07:20 PM   eBay Motors   #19 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
For the Color-Blond
The highest bar is the LBZ mouthpiece only, the next highest shows how little drop there is when adding the rest of the intake for testing.
Old 07-19-2009, 11:16 PM   eBay Motors   #20 (permalink)
Toypuller
Thanks for the info. Its great to have actuall facts like killerbee has supporting these mods.
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
Toypuller is online now   Reply With Quote
