"CHANGE FUEL FILTER" light - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 07-19-2009, 09:21 PM Thread Starter
So I changed my fuel filter the other day, but the reminder that comes on whenever I start the truck won't go out. I looked in the owner's manual and it wasn't mentioned...or I couldn't find. I figured since they tell you how to get the "CHANGE OIL/FILTER" light to go out, that they'd tell you about the fuel filter light too. Anyone know how to do this?:rockin:rockin
Work harder, millions on welfare depend on you.05 LS Crew Cab short box 4x4. Under the hood: motor and tranny. :rockin:rockin
Tack is offline
post #2 of 13 (permalink) Old 07-19-2009, 09:23 PM
should just have to scroll through on your DIC to find it and push and hold the lower right "arrow" button on the steering wheel...
'05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin
K9Duramax is offline
post #3 of 13 (permalink) Old 07-19-2009, 09:47 PM
I think that if you have it on chnage fuel filter and pump the brakes thre times it may reset
2006 gmc slt,full bore exhaust maniflod,leather,dee zee nerf bars,Diamondback hd tonneu cover,cloud rider mud flaps ,trans go jr with bd valve body, cognito level installed uca , ppe tie rod sleeves,atx teflon,pro comp shocks edge evoloution A/T.295/70/17 nitto terra grapplers::die NOW WHERE ARE THE CANADIAN TRANNY BUILDERS
marbles72 is offline
post #4 of 13 (permalink) Old 07-20-2009, 09:23 AM
Its just a worktruck
DMAXchris's Avatar
If you dont have the DIC, You hold down the brake and gas pedals for 15 seconds with the key on. Engine oil life reset is Hold the gas and pump the brakes 3 times.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #5 of 13 (permalink) Old 07-20-2009, 02:34 PM Thread Starter
this method worked. thanks!:rockin:rockin
Tack is offline
post #6 of 13 (permalink) Old 07-20-2009, 04:51 PM
ethanjensen's Avatar
For the oil life reset when I did the "Hold the gas and pump the brakes 3 times" it would just turn my high idle on or off.
Is the LLY different from the LBZ?
2007 2500 LBZ EC/SB
Quadzilla Stealth 2@90hp
MBRP 4' turbo back
T-Bars cranked
BFG All-Terrain 285/75/16
Pro-Comp Rock Crawler Black Street Lock Wheel
Tractor Supply Gulwing Toolbox
AMI Locking Fuel Door
http://www.getsomeperformance.com/
Coming soon ...
Autometer Cobalt pyro and boost A-pillar mount
ethanjensen is offline
post #7 of 13 (permalink) Old 07-20-2009, 06:45 PM
DMAXchris's Avatar
I think you're right about high idle. Now that I thought about it, you press the gas pedal 3 times and hold it for oil life.
06 LBZ EC/LB 4x4
post #8 of 13 (permalink) Old 07-20-2009, 07:28 PM
O.K. thanks it worked.
2007 2500 LBZ EC/SB
MBRP 4' turbo back
T-Bars cranked
Coming soon ...
post #9 of 13 (permalink) Old 07-28-2009, 03:44 PM
I had the same problem, I changed the fuel filter and could not find in the book how to reset the (change fuel filter) I called the Chev dealer and he just said to bring it in, they had to hook it to the computer to reset it (I suspose for a nice fee) I fooled them, found out how here, THANKS GUYS, saved a few dollars. Real simple, turn on the key with the change fuel filter message showing and hold down the break and gas pedal at the same time for about 15 sec's and it shows reset. Now why would the Chevy place not tell me that?
Halfcell is offline
post #10 of 13 (permalink) Old 07-28-2009, 03:48 PM
02lb7dmax's Avatar
because they want your money!
Ian Love | Husker Diesel | 402-502-6961
Blocker Plates | WIF Wrench | Fuel Filters
www.huskerdiesel.com | Email us!
2006 LBZ, EFI'd, tranny by HDP, HDP built motor/ twins, cam, head studs, main studs, big air puppy, mahle pistons, carrillo rods, etc etc etc
2002 LB7, EFI'd, HDP 5, HDP built trans, air puppy, and some 20" thumps"
02lb7dmax is offline
