Transmission Problems - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 11-10-2007, 07:58 PM Thread Starter
Super Moderator
BigRedChevy's Avatar
Yesterday when i was driving down the road my transmission locked me out of OD and was stuck in Drive(even when i stopped and took off again it was in drive, did not start in 1)and i did not get a rev limiter. When it happened i was running 80 or 85 but was now accelerating hard or anything like that. My SEL came on and when i checked the codes i had a P0700 and a P1621. Do you all have any idea what might cause this.
BigRedChevy is offline
post #2 of 21 (permalink) Old 11-10-2007, 11:51 PM
Administrator
ob_1jr's Avatar
sounds like you limped your tranny. what power level were you at with your programmer? The stock 5 speed can only take about 85-100 extra hp. Basically the tranny was slipping in 5th gear and went into failsafe mode.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #3 of 21 (permalink) Old 11-11-2007, 04:58 PM Thread Starter
Super Moderator
I was on the 90hp setting. Would it be slipping even though i was not pulling hard. I was running fast but i didn't accelerate hard to get there. I also wasn't towing anything.
post #4 of 21 (permalink) Old 11-11-2007, 09:10 PM
Maverick684's Avatar
Yeah that defintely is limpin the tranny. I run my edge on level 4, about 90HP. When I pull my small trailer behind me and try to merge on the freeway it has done the exact same thing before. If it happens again just pull over and shut the truck off and wait a couple minutes then restart it. It will reset it and you should be fine.
John
05' Dmax LLY CC SB, 6in.Fabtech, 20x12 Fuel Krank's, 35in Trail Grapplers and some other stuff
2012 Jeep Grand Cherokee SRT8
2003 Cummins SC LB
Maverick684 is offline
post #5 of 21 (permalink) Old 11-11-2007, 11:32 PM
Administrator
ob_1jr's Avatar
5th gear is a weak gear and doesn't hold very well. You were probably building boost and all it takes is to go up a small hill and then you slip 5th. Most of the time the truck will limp on the 4-5 or the 5-4 shift.
X-pel clear bra
ob_1jr is offline
post #6 of 21 (permalink) Old 06-07-2009, 07:24 PM
My truck did that the other day. But mine is bone stock and it locked me out of reverse too. I shut it off a couple of times and the MIL shut off and it shifted fine again. But every time I get on in on the free way it does it. My dad's friend who own's the car lot I bought it from has the same truck but an 04 with a tune and he has never had that problem. Any takes?
Dieseldevin88 is offline
post #7 of 21 (permalink) Old 06-07-2009, 07:26 PM
delong_1's Avatar
wow this is an old thread
built motor, big turbos, built trans, etc all by me, parts from Elite Diesel
1016 hp
7.1 1/8 @ 100
11.27 @ 105
delong_1 is offline
post #8 of 21 (permalink) Old 06-07-2009, 07:38 PM
mysupersportss's Avatar
Do you guys think a scIV would limp under those coditions or did I miss something?
New project: LMM Crew
Sold: Crew short bed 4x4 LT3 LBZ
Magnaflow 5in TB Exhaust-AFE Stage 2 Resonator Plugged
Painted Door Handles-6000k HIDS-Double Din DVD
Autometer Phantom Gauges
PPE with transgo
Cst 9-11 lift set @ 10" W/bilstein 7100's
37" Toyo MT's on 22" trax8 wheels
Sold: LLY LT Lifted on 37's
Big thanks to Mike @ Dmaxstore
For all you Wheel and Tire needs shop http://www.discounttiredirect.com
mysupersportss is offline
post #9 of 21 (permalink) Old 06-07-2009, 07:57 PM
Ok, old yes, but...
I think you may need to take it in for the dealer to reflash the TCM to fix this.
Yes, I do believe it would.
bigdaddydiesel is offline
post #10 of 21 (permalink) Old 06-07-2009, 08:39 PM
SDP
Scott@SDP's Avatar
I'm thinking this was before he had the SC4 in.
Not with a stock turbo thats for sure. I haven't heard of a limp like this happening at all with a SC 4 though.
Screamin Diesel Performance 360-417-9000 Scott@SDPtwins.com
Compound twin turbo kits with 3" y-bridge and coolant tank for all Duramax's
SDPtwins.com LIKE US ON FACEBOOK!
2016 2.8L Duramax Canyon with SDP Compound twin turbo kit and DSP4 tuning
2009 LMM SDP trans, SDP GT5541/GTX42 twins, 200% injectors, 2x Exergy CP3's, Socal motor, ATP tuned
2002 LB7 SDP twins, ATP tuned, stock motor 11.97@113mph 7,200lbs
2001 LB7 SDP Built transmission, Single SDP S475, ATP tuning
2006 LBZ Race truck build
Scott@SDP is online now
