EGR Valve - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 09-09-2009, 02:46 PM Thread Starter
bigdaddy1385's Avatar
EGR Valve
My 04 LLY seems really sluggish in the morning. It seems like it has no power for about two blocks and seems like it warms up or something after that. After those two blocks it runs fine. I was told that it is quite possibly a stuck egr valve. Any other ideas? What could i do to try to fix it?
2004 White LLY
EFI Live by IdahoRob, ADII 165, 5" exhaust & 6" chrome tip
Edge Insight CTS
AFE MP and AFE Stage 2 Intake
Blocked, Plugged, and Rerouted
Cowl Hood, 6k Highs, 5k lows and fogs, All-On Mod, smoked led cab lights, tails and 3rd brake light, nbs logos
Moto Metal 951, 305/60/18 Mickey Thompson ATZ, 3" torsion keys & 1.5" rear blocks, traction bars, tie rod sleeves
bigdaddy1385 is offline
post #2 of 7 (permalink) Old 09-09-2009, 11:08 PM
Oldvintageiron's Avatar
I'm sure that the truck just needs to worm up, just like any motor the motor needs heat in it to run. I've never had this issue on my LLY but i don't hot rod it in the moring. Get a scaner and check the codes, alot of the time the EGR wont through a engine light. Get yourself an EGR block plate anyways and that will shut the EGR off completly. GOOD LUCK
2004.5 lly GMC CCSB 2500
Stock LBZ intake, AFE MP, Afe IC Tubes both sides, MBRP DP w/ heat wrap
BD manifold, EGR block plate, Banks turbo back(no cat) ,coolant bypass filter
EFI Live by IDAHOROB w/DSP5http://www.atptrucks.com
Aeroforce Interceptor gauges, ARP studs,
19.5 Rickson wheels W/ 225/70/19.5 drive/ steer
BD Flowmax Lift pump, auxiliary fuel filter PPE fprv shim
Bullydog shift enhancer/ Amsoil Race Trans Fluid, MA pump rub fix.
Amsoil Bypass Filtration, Amsoil 3000 5w30 oil
Cognito Motorsports Pitman/ Idler support kit,Secondary Radiator system built by me
Oldvintageiron is offline
post #3 of 7 (permalink) Old 09-09-2009, 11:12 PM
Chevyguy08's Avatar
um the egr with throw codes and an engine light if there is an issue with it
P0400 Exhaust Gas Recirculation Flow Error
P0401 Exhaust Gas Recirculation Flow Insuff Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circ Error
P0404 Exhaust Gas Recirculation Circ Range/Perf
P0405 Exhaust Gas Recirculation SensorA Circ Lo
P0406 Exhaust Gas Recirculation SensorA Circ Hi
P0407 Exhaust Gas Recirculation SensorB Circ Lo
P0408 Exhaust Gas Recirculation SensorB Circ Hi
P0409 Exhaust Gas Recirculation SensorA Circ
08 LMM is alive and well again with a few add ons
2011 3500 Denali
2011 2500HD LTZ
2011 1500 LTZ
Chevyguy08 is offline
post #4 of 7 (permalink) Old 09-10-2009, 12:31 AM
Can you read?:Smack I said engine light, I never said it wont through a code. I've had p0401 on mine sence I have a EGR block plate, the engine light never came on and has been a nonissue.
post #5 of 7 (permalink) Old 09-14-2009, 08:04 AM
If your EGR is stuck or bad, your truck will smoke like a freight train! Had it happen several months ago.
2004.5 LLY GMC 2500HD SLT, CC SB
4" MBRP turbo back exhaust
AirRaid CAI
Edge Juice w/Attitude
"If it ain't broke, it ain't MINE!!"
DieselHawg is offline
post #6 of 7 (permalink) Old 09-14-2009, 11:56 AM
1953drtelco's Avatar
Was it stuck open for all the smoke? Otherwise if it was stuck closed, wouldn't it act like the EGR blocker plate?? I didn't have much smoke on my stock truck before I installed the EGR blocker plate, and almost no smoke since I installed the blocker plate...
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 115K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline
post #7 of 7 (permalink) Old 09-15-2009, 07:23 AM
Not sure if it was open or closed, but I can tell you for sure, it smoked like I was running on shredded tires. My guess would have been stuck open.
AirRaid CAI
