LLY oil pressure - Chevy and GMC Duramax Diesel Forum
post #1 of 22 (permalink) Old 09-24-2009, 02:33 PM Thread Starter
D.W.'s Avatar
LLY oil pressure
Im not sure if this has been talked about before, but when my truck is at operating temp it idles at about 30 psi, and when cruising down the road at 65 mph, its at 55 psi. I use rotella oil and fleetguard filter. Im a diesel tech for kenworth, and im used to seeing big oil pressure readings, these seem kind of low to me, never had a check engine light or anything, and the level is always at the full mark. Just wondereing if anyone else's engine is like this.
Thanks, Derek W.
2005 Chevrolet 2500HD crewcab LLY, LT3 package
Banks 4" Monster Exhaust, S&B cold air intake, Kodiak mouthpiece and MBRP cat delete pipe
Recon "Line of Fire" LED tailgate Bar
B&W turnover ball, Pac-brake air springs
BF Goodrich All-Terrains 285/75/R16 on stock rims
Mods to come:congnito tie rods, and PPE Excellerater Standard
Other Ride: AKA the commute car
1993 Ford Probe
Broken headlight that stays up, primer grey hood:rockin
D.W. is offline
post #2 of 22 (permalink) Old 09-24-2009, 02:56 PM
Its normal. Thats about where my 05 operated at and my LMM is about the same as well. Ive seen mine idle lower than 30psi often, especially after the engine is up to temp.
07.5 LMM Chevy CCSB Z71
Edge Evo Race, Banks Ram Air,
MBRP 5" Exhaust, Diamond Eye DP,
EGR Blocker Plate, PCV Reroute Mod
6" Fabtech, 18" Chrome Diamo 8 Karat
35"X12.50" Toyo Open Country M/T
Mag-Hytec Rear Diff Cover, Transgo Jr.
Thanks Meyer Performance and MadJack Racing.
CHYKYNLIPS is offline
post #3 of 22 (permalink) Old 09-24-2009, 05:39 PM
Yup, thats where mine runs at.
2005 2500 hd sb/cc
4" mbrp turbo back
hypertech chip
lbz mp, modified stock intake, ppe egr plate/false code box
air bags rear
leveling kit front
bf goodrich at 295/75 16's
itsjustatruck is offline
post #4 of 22 (permalink) Old 11-27-2009, 12:05 AM
Davis Dresser's Avatar
mine gets really low when it is ideling just a mark or two above red
2004 Gmc Duramax lly
magnaflow exaust, exaust brake, air raid intake
Rancho 4" lift, air ride bags. 35" procomp tires. motto rims, Mag-Hytec Rear Diff Cover
train horns, york compressor, B&W gooseneck
IssPro EV2. EGT, Boost, Exh Backpressure
road armor with warn 12k
160,000 miles
http://dmaxstore.com/
Davis Dresser is offline
post #5 of 22 (permalink) Old 11-27-2009, 02:23 AM
DuramaxSMOKE11's Avatar
Send a message via AIM to DuramaxSMOKE11
the duramax engine at operating temps is soppose to have 25lbs at idle
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
EFI LIVE TUNED BY NICK
Big thanks to chad at Alligator performancewww.alligatorperformance.com
DuramaxSMOKE11 is offline
post #6 of 22 (permalink) Old 11-27-2009, 02:30 AM
Administrator
ob_1jr's Avatar
yeah, but you cant always trust the cluster....they arent always that accurate. If you want to know for sure put an aftermarket guage on it.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #7 of 22 (permalink) Old 11-27-2009, 02:32 AM
^^^X2 on that
Mike
post #8 of 22 (permalink) Old 11-27-2009, 12:43 PM
duratothemax's Avatar
no thats incorrect.
minimum allowable spec is 14 psi hot at idle, and 48 psi at 1800rpm.
ben
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #9 of 22 (permalink) Old 11-27-2009, 12:45 PM
yes they are. Every duramax ive ever worked on, the oil pressure gauge was just about spot on.
The only gauge in the duramax instrument cluster thats not 100% accurate is the coolant temp gauge.
The trans temp and oil pressure gauges are very accurate. This isnt a ford we are dealing with here...
ben
06 audi S4, V8/6spd
post #10 of 22 (permalink) Old 11-27-2009, 12:51 PM
1953drtelco's Avatar
My truck does the same thing....
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 115K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline
