oil dipstick problem major issue? - Chevy and GMC Duramax Diesel Forum
Old 10-02-2009, 12:29 PM   eBay Motors  #1 (permalink)
i checked my oil today pulled dipstick wiped the end of it put back in pulled it out to verify oil level and guess what no more indicator at the end of the cable dipstick. i'm guessing now i have to drop the oil pan to get the piece out? either way i didn't start the truck and its now sitting still in the driveway. anyone have this happen yet? it seems like the the cable dipstick w/ the soldered on end isn't that great of a design. hopefully it will be in the bottom of the pan when i drop it.
04.5 lly 2500hd silverado
4in mbrp ss catback
mouthpiece upgrade
farmerjim is offline   Reply With Quote
Old 10-02-2009, 12:34 PM   eBay Motors  #2 (permalink)
Quicker Then Brian!
RedBowTies88's Avatar
oh wow...that sucks man. first time hearing of this happening...
good luck with it and im curious if that will get it out
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
Old 10-02-2009, 12:36 PM   eBay Motors  #3 (permalink)
Banned
Thats thinking with your dipstick.
Old 10-02-2009, 12:38 PM   eBay Motors  #4 (permalink)
EFI'd and lovin it
Johnasara's Avatar
I would see If you could not find a long skinny magnet and drop down there before Dropping the pan.
EXHAUST,EFI LIVE,DSP5,TPTUNED BY KORY WILLIS,S&B COLD AIR INTAKE
WORK RIG
O7.5 3500 CREW,DUALLY, LMM, ROYAL UTILITY BED...STOCK......ISH
This is not only your forum you have to share it with over 80,000 others
Old 10-02-2009, 12:39 PM   eBay Motors  #5 (permalink)
Quicker Then Brian!
Thanks to,
Old 10-02-2009, 12:40 PM   eBay Motors  #6 (permalink)
rap2orrider660R's Avatar
Not sure if a auto magnet would work.. I would bet the braded cable is a stainless alloy
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS
rap2orrider660R is offline   Reply With Quote
Old 10-02-2009, 12:42 PM   eBay Motors  #7 (permalink)
Administrator
ob_1jr's Avatar
But is it magnetic? I dont think it is, but i could be wrong. I cant test your theory. Maybe by draining the oil it might come out... a real long shot, but draining and borescoping the pan would be great.
SOLD
305/70-16 BFG T/A KOs on Eagle Alloys Series 187
Clifford remote start. High Idle, Bilstein 5100s, 1.5" lift blocks
CAT fuel filter w/ nicktane adapter
Magnum Force Stage 2 intake with AMSOIL filter
Racor 2 Micron pre-OEM with heater & water sep
Lightforce 140s from Madjackracing
http://WWW.ATPTRUCKS.COM/
Old 10-02-2009, 12:46 PM   eBay Motors  #8 (permalink)
Crusher's Avatar
Maybe jack up the front before draining oil. good luck
2006 Chevy 2500HD LT CCSB 4X4 Duramax LBZ;
EFILive V2 Tuned by IdahoRob, FASS HD-C10-150G,
BANKS Ram Air Intake + Super Scoop, Banks Boost CAC Tube, BD Exhaust Manifold, EGR Blocker, MBRP DP, 4" Turbo-Back Exhaust w/ Aero-Turbine 4040, PCV Reroute, Transgo Jr., B&M Racing Deep Pan, Pure-Power Filter, SunCoast Deep Filter Lock,
Autometer Ultra-Lite II - EGT & Boost in overhead. NCT/Bilstein Shocks, Sulastic Shackles, Kryptonite Tie-Rods, Cognito UCA & Steering Braces, Firestone Ride-Rite Airbags, Reunel Bumper, Open Country M/T, LINE-X, TruXedo Tonneau, Pro-Tech Toolbox, Pioneer FH-P8000BT, i-pod, Focal 165KF Frt & Rear, JL Audio 300/4 Amp, Focal 27KX Subs, Audison Amp, Rattle-Trap Xtreme.
Crusher is offline   Reply With Quote
Old 10-02-2009, 12:47 PM   eBay Motors  #9 (permalink)
Banned
Old 10-02-2009, 12:48 PM   eBay Motors  #10 (permalink)
dipstick
i don't think the end that has the indicator hatch marks is magnetic, it seems to be more like a lead fishing sinker? does anyone know if the dipstick hole goes straight down into the pan? either way i will be draining the oil and probably dropping the pan to get it out.
4in mbrp ss catback
mouthpiece upgrade
