Injector leak - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 10-13-2009, 07:37 PM Thread Starter
prbishop12's Avatar
Unhappy Injector leak
On my 2005 Chevy LLY it appears I have a leak coming from injector #5 (third one back on driver side.) Has anyone else run into this issues? Anyone know if there is a recall or where I can find a rebuild better then $450?
I tried loosening it and tightening it back up doesn't appear to help the situation... Also it only leaks when driving it won't leak at idle also no indication of check engine light has come up and the truck seems to be running the same as before the leak.
Any feedback would be awesome! Thanks
Last edited by prbishop12; 10-13-2009 at 08:35 PM. Reason: Included truck description
prbishop12 is offline
post #2 of 5 (permalink) Old 10-14-2009, 10:32 PM
yep yep...
WVRigRat08's Avatar
ther is a little copper o ring that is the injector seat it sits on your lower valve pan cover may have washed out i hope your vavle pan didnt wash out the tq specs on the injector bolt is 30 ft/lbs take an air gun and blow out arond the injector to get any dirt out around it and break the line loose at the fuel rail and the injector so you can get it out of the way and easily use a screwdriver and pry up on the crows foot that holds the injector in and wiggle the injector while you pull up on it look and see if the copper seat is washed out theyre very cheap if so and also check the valve pan where the injector goes. if its leaking out of the top little black hose thats your return line its got a little o ring it may be bad if that where its leaking.
05' Chevy LT Black on Black LLY CC/SB Blackout Performance built motor/trans/tuned- Gone
"The Blessed Hellride"-08' GMC Sierra SLT Z71 CC/SB White
Big Dipper Reger proof trans, some sissy tunes, 35's and old school built front end
Done with it
WVRigRat08 is offline
post #3 of 5 (permalink) Old 10-15-2009, 10:44 AM Thread Starter
prbishop12's Avatar
Thanks for the reply, I will check into this tonight and let you know what I find!
Ryan
2005 Chevy Duramax 6.6 LLY 4X4
Quadzilla Stealth 2
4" exhaust/ AFE Mouth Piece
6" lift
MKW M26 18 " rims
35x12.5 Nitto Terra Graplers Tires
Electric Tow Mirrors
http://www.discounttiredirect.com
:gungun1
post #4 of 5 (permalink) Old 10-15-2009, 10:56 AM
yep yep...
WVRigRat08's Avatar
im leaving town tonight but hope that helped you out
Done with it
post #5 of 5 (permalink) Old 10-20-2009, 11:37 AM Thread Starter
prbishop12's Avatar
okay, removed the Injector everything looks like its in good shape cleaned the surrounding area, reseeded the injector until I could buy a new one and the leak is gone... Must have just needed to be taken out and put back in to get that tight fit again?
Ryan
Quadzilla Stealth 2
6" lift
MKW M26 18 " rims
:gungun1
