Old 10-26-2009, 09:05 AM   eBay Motors   #21 (permalink)
BigBlueGMC
Originally Posted by midieselguy View Post
JC1843 was asking the same questions I was thinking. I went from a chevy 454 to the LLY like you bought about 1-1/2 years ago and have had a smile on my face ever since. My truck pulls a 9,000 lbs load on flat ground like its not even there. You notice it under acceleration but you can tell the truck could handle twice as much. When pulling grades, did you make sure your tow/haul switch was on? This will prevent your truck from gear hunting while pulling grades. You can also shut the OD off and lock in 4th if you notice that's where the truck would like to run.
When I hit a grade, I slow the truck down to 60-65 and disable OD. Truck then pulls the grade without a sweat.
I agree that the IOH kit is an excellent improvement but it didn't give me much more pulling power, just reduced temps while pulling.
I hope this helps, I think you might be expecting too much from the truck. 9,000lbs is some weight, you'll feel it back there, but I bet your diesel will run circles around that old 6.0.
I just noticed your post. I didn't take it out of overdrive because I heard the Allison adjusts automatically so to speak.
That may have helped! I did try the tow/haul mode on a few of the inclines and noticed a slight difference, with cruise control on and set to 68, it did seem to pull up the incline a little better, but the rpms still jumped from 2000 to around 2700 or 2800 until I reached the top of the incline.
Maybe I just need to get to know the truck better and adjust my driving habits, been towing with gas engines for a long time, maybe an adjustment is needed on my part!!!
BigBlueGMC is offline   Reply With Quote
Old 10-26-2009, 09:09 AM   eBay Motors   #22 (permalink)
RedBowTies88
RedBowTies88's Avatar
true....it is a little different from driving a gas engine..
on another note..the egr delete.block will help with inclines...mine downshifts much less since i blocked it..
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 10-26-2009, 09:24 AM   eBay Motors   #23 (permalink)
BigBlueGMC
Originally Posted by Killerbee View Post
You have defined thermal feedback. Lots to understand.
http://members.cox.net/td-eoc/LLY%20...verheating.pdf
I read the article and from what I could understand I should get the LBZ MP, a true cold air intake, and efilive whatever that is!
I'll check out the efilive, is it an effective mod?
Did I miss anything?
Old 10-26-2009, 09:27 AM   eBay Motors   #24 (permalink)
RedBowTies88
you just need a new mouthpiece dont worry about anything else yet man..
EFI Live is an awesome thing...but there is tons to understand with it and you dont need it yet..
its more or less a tuner....its the best one there is...its also the most complicated. its a great thing to have but not needed and certainly not urgent...your just starting out so i would worry about that down the road more
LLY Cc/sb 4x4 RED
Old 10-26-2009, 09:29 AM   eBay Motors   #25 (permalink)
Killerbee
Killerbee's Avatar
EFILive is just a piece of software. It is every bit as bad, or good, as the skill level of the person doing the key entry.
Michael, 2500HD LLY, Systems Engineer, EMAIL
PRODUCT PAGE CUSTOM TUNING
Quick Links:ECM's , INDUCTION OVERHAUL, EFILive,
NEW Lockable DSP Switches coming DEC 1
Old 10-26-2009, 09:33 AM   eBay Motors   #26 (permalink)
Killerbee
Killerbee's Avatar
I read the article
All 4 of them?
Old 10-26-2009, 09:37 AM   eBay Motors   #27 (permalink)
BigBlueGMC
Killerbee, All four of what?
Old 10-26-2009, 09:39 AM   eBay Motors   #28 (permalink)
MaddMax
Hi,
Let me start by saying I never owned a diesel truck before, so I don't know what to expect from it or what driving habit adjustments I need to make now that I own one!
I just bought a 2004.5 GMC Sierra SLT 4x4 crew cab with an 8ft bed!
It has the Duramax Allison combo.
It has 110K miles and seems to drive like new, except when towing!
I picked it up with my 2003 Chevy 2500HD (6.0 gas) 120 miles away!
I hooked the trailer to my new GMC diesel and loaded my 2500HD on the trailer.
I found that on level grades it pulled the trailer fine, but when on the highway and dealing with long inclines, I felt it did a terrible job of pulling on the inclines! Isn’t this where a diesel is supposed to shine!!!
Ok, with that said I checked the internet and found all kinds of articles slamming the LLY engine.
I also found a lot of articles and ads for an LLY Induction overhaul kit, True cold air intake, the Duramileage EZ tuner and many other upgrades. My pockets are only so deep so the big question is:
Are there design flaws with the LLY that should be addressed first and if so which ones are most important and which ones will give me better towing performance and a boost in HP and correct the things GM should have done in the first place???
Any and all comments would be appreciated!
I know there is a lot of info in this forum, but I can’t seem to find the answers I need, so I posted this thread to help me get my truck running the best it possibly can!
So which upgrades should I do first!!!
Thanks in advance,
Brian
Brian,
Congradulations on joining the diesel fraturnity. First of all don't always believe what you read about LLY's or any other diesel engine on the net. Like someone else already mentioned, you hear more about the bad stuff than the good stiff. Getting your LLY breathing better is probably the best investment you can make. The mp and a good free flowing intake and exhaust system will make your truck run much better. Adding a programer can also show benefits in power and mpg. You also need to remeber that diesels operate in a different rpm power band than a gas engine, and it does take a little getting used to at first. I've towed a simular load as you described with my LLY and it performed flawlessly and even managed 16 mpg on level highway. Hope all this information helps. Good luck with your new truck!
Mark
2004.5 Chevy K2500 Duramax
aFe Stage 2 Intake
MagnaFlow Turbo back 4" Exhaust
Stacked Hypertech/Edge programmers
LT285/70R16 Dick Cepec Crushers with stock suspension and no torsion bar adjustment. (removed)
went back to LT265/75R16's for now.
18/city, 22/Hwy, 16/towing 10,000 pound trailer.
MaddMax is offline   Reply With Quote
Old 10-26-2009, 09:44 AM   eBay Motors   #29 (permalink)
Killerbee
Killerbee's Avatar
Four articles imbedded in the link above.
Old 10-26-2009, 10:04 AM   eBay Motors   #30 (permalink)
BigBlueGMC
Yeah, I read them all.
This is my plan for starters:
LBZ mouthpiece
EGR blockoff - where can I find this?????????????
TCAI
If you or anyone else can recommend any other inexpensive mods that I don't have listed above then please let me know about them.
Thanks again for all the replies and help! You guys are great!!
