04.5-05 LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
So when you limp the tranny it locks it in 4th gear and disables the reverse? I thought limp mode limited you to 2k rpms, but the trany still opperated normaly. Or is that just the P1093 code I'm used to that limits you to 2k rpms?
2000rpm limit is only on fuel related limps
Originally Posted by ob_1jr
when you actually limp the tranny, it wont shift into 5th and will be limited to 2000. I never tried to put it in reverse when i limped it bad like that...just pulled over and shut it off.
there is no rpm limit but it will not shift into 5th and the converter will be extremely extremely loose and power at take off will be reduced a lot. and no reverse like you experianced
Originally Posted by pwrtripls1
I hope y'all are right, I'll go out and start it in a few minutes and see if reverse works. If it does the Edge is going on 1/1 and staying there till I get the trans built. I cant afford to build it now, but I cant afford to park it for the next couple months either.
we're right dont worry im an expert at trans limps..
you'll be fine and you can run the edge on a mileage tune IF you can RESIST the urge to give it power in 5th gear
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Yeah, i think you're right about the rpm limit...it just doesnt shift. I remember doing about 80 when mine limped....heehe...pulling a long hill and had it floored and i was in 5th...then of course it downshifted to 4th and i was at about 2500 or a little more RPMs...been awhile since i limped my tranny. Been a little smarter about driving it....not much though
all I can say is those little transgo valves do great things I haven't limped mine yet I've done burnouts and 0-135mph at wot all with 37's it has to hate it's life and it still holds...there is usually a little clutch material in the fluid when I drain it though
__________________ DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
x2...you lucky 6 speed sob..
the op is talking about his lly so we can really use them
LLY Cc/sb 4x4 RED
Well it was just in limp mode. When I fired it up everything was fine. I hooked up a 24' enclosed trailer weighing just over 12k and halfway into Houston the service engine light went off and hasnt come back on since. I pulled on the tow setting, lvl 2, and 5th gear held fine so I dont think I did any real damage limping it that time. Hopefully I dont do it again before January.
one the clutches slip they are never the same again..so if your towing i would not run anything over stock power at all...
driving empty you may be able to get away with something like a 50 horse tune for a while but its still taking a chance
LLY Cc/sb 4x4 RED
I have the edge display set to show trans slip % and I kept an eye on it while pulling in 5th gear yesterday. It stayed at 0.0 so I guess its alright. I'll keep an eye on it and if it shows any slip at all I'll drop the power down more.
So it it still ok to run lvl 4 or 5 at the 1/8 mile track? I run with the OD off so its only 1st thru 4th gear.
the gauge isn't going to hlp you becuase the tcm is going to read the slip before it does and put you in limp....
theoretically long as you dont go into 5th you should be ok for that power lever but its not a definite...
LLY Cc/sb 4x4 RED
