Old 11-03-2009, 02:54 PM   eBay Motors   #1 (permalink)
Dcattech
Thread size
I need thread size of a egde egt probe for the manifold. Have a relative getting rid of his truck and wants to remove his programmer. Size and depth of bolt I would need to plug the hole would be appreciated thanks.
2005 Chevy 2500HD CCSB Duramax
4" straight pipe,volant cool air intake, edge juice with attitude (junk), kodiak mp, egr and egr cooler removed,
lt265/75R16s
Soon to get 285/75R16's, Stage IV trans(beginning to slip in
5th), d-pipe, EFI, and BIG single stack.
Dcattech is offline   Reply With Quote
Old 11-03-2009, 03:04 PM   eBay Motors   #2 (permalink)
Vrabel
Vrabel's Avatar
1/4 pipe I believe.
Not Quite Stock.
Vrabel is offline   Reply With Quote
Old 11-07-2009, 07:10 AM   eBay Motors   #3 (permalink)
Bwest99svt
I know when I tapped mine i used an 1/8" npt tap.... Dont know if that helps or not
2005 LLY 2500HD Crew Cab short box
4" MBRP turbo back... AFE stage II intake
AFE Mouth piece... 285/75/16 BFG's
PPE Xcelerator Standard... EGR block off
Bwest99svt is offline   Reply With Quote
Old 11-07-2009, 07:17 AM   eBay Motors   #4 (permalink)
farmer14
farmer14's Avatar
yup thats what the directions say. also use a 5/16 or 21/64 drill
2007.5 2500 ltz fully loaded crewcab,
banks air intake with scoop,
truxx 3inch lift, 33/1250r20
nathan k5la train horns,
b&w hideaway goose & 5th wheel
stealth 2, stacked with banks pda,
banks speed brake
mbrp duals-dpf & muffler delete
fire & ice lightbar, resonator plugged, egr blocked,transgo jr
farmer14 is offline   Reply With Quote
Old 11-07-2009, 07:08 PM   eBay Motors   #5 (permalink)
05LLYMaxx
Yep, its a 1/8" NPT. Just go to home depot and pick up a 1/8" NPT plug in the plumbing department. I had to go get one today, removed my Edge. Trying to sell it.
05LLYMaxx is offline   Reply With Quote
Old 11-07-2009, 07:23 PM   eBay Motors   #6 (permalink)
treyfox11
treyfox11's Avatar
different guages use different sizes mine just happen to be 1/4 npt but have seen 1/8 npt just get both they are not that much
06 lbz cc/sb ,afe intake,mbrp 4in turbo back exhaust
ppe tie rod sleeves,egr blocked
di-pricol guauges(boost and pyro)
ported fuel rail fitting,fuel valve shimmed
Air Dog II 165 lift pump
stage 5 tranny built by me
Efi live tuned
Bruce Lee can kick Chuck Norris's A**
treyfox11 is offline   Reply With Quote
