04.5-05 LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
ok I have an 04.5 LLY that pulsates when your at a stop sign. Meaning it feels like you tap the gas when your sitting at a stop sign. Does this sound like a fuel pressure regulator? If a put additivies in the tank it helps out the problem but comes back after a while. What do you guys think?
IDK, I put a lift pump on mine and the pulsating symptom stopped. I am curious to see what it could be and if it may reoccur down the line.
__________________ PIN IT TO WIN IT
2003 2500HD ECSB Duramax
38,000 Miles
AFE Stage 2 Intake
AD100- Thx Todd MPF
285/75/16 MTR's
Every window 20%
ya i fixed a guys truck who had the same thing and the fpr fixed the problem. but if you have diagnostic equipment there is a way to look at this. if you can look at the fuel pressure put it in a graph and it should be a smooth wave look. if it is spiking hi and low of desired it will need a fpr. good luck
__________________ 07 lbz silverado 2500 crew cab
285/75/16 tires
egr blocker plate and chip
dual staight pipe exhaust
stage 3 afe intake
edge juice with attitude
I had a pulsating/surging idle too. Not noticable on TAC or EGT but you could definetly hear it. Replaced the FPR last month. I have not heard it again. Hope this helps. Check your warranty, stealership fixed mine for $80 deduct. I think if you buy the part yourself its somewhere around $200. Diesel Place has a DIY.
__________________ 2005 Chevrolet 3500 Silverado LT
4X4 CCLB
LLY
Edge Attitude /w Juice
Volant CAI
4" MBRP
2" Leveling Kit
Protech Headache Rack
LINE-X
Could be something as simple as a leak in your fuel system as well, though... I had the same symptoms, and it was a bad o-ring in my WIF sensor. I didn't see any visible fuel leaking out (particularly becaue it's right near the A/C dump spot) but it was only a $70 fix...
Just something else to check...
__________________ Nick
Lynnwood, WA
2005 2500HD CCLB
Edge w/ Attitude
4" Silverline w/o the kitty
Pulled out the AFE Stage II for an LBZ MP and stock intake - anybody need an AFE Stage II? ;-)
From Air Dog:
Rough idle results from the inconsistent injection timing due to the variation of air/vapor present in each idle injection. The delayed injections also cause the idle speed of the engine to drop below the desired RPM. Consequently the ECM then must increase the ammount of fuel injected to bring it back to proper idle. This adds more fuel than the engine can completely burn, if this continues for a consireable ammount of time, if the idle is not brough up by 800 to 1000 RPM, the excessive fuel washes oils from the rings and liners, contaninates the oil in the crank case and causes extensive engine wear.
38,000 Miles
AFE Stage 2 Intake
AD100- Thx Todd MPF
285/75/16 MTR's
Every window 20%
