Old 11-05-2009, 10:34 AM   eBay Motors   #1 (permalink)
Follmer
Follmer's Avatar
Oil amounts
Anyone have all the amount of oil to fill the following components?
Engine
Tranny
Brake Fluid
Differentials
Transfer case
Switching all fluids and need to obtain the information in order to place my order. Thanks!
-Josh
2004 2500 LB7
EFI Live from Husker Diesel
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
Follmer is offline   Reply With Quote
Old 11-05-2009, 10:51 AM   eBay Motors   #2 (permalink)
scottdomine
scottdomine's Avatar
Engine
Tranny
Brake Fluid
Differentials
Transfer case
Engine oil is 10 qts.
Trans depends on what exactly you're doing. I did flush via hoot method and used 3.5 gallons.
Brake fluid ?
Front diff takes just under 2 qts
Rear diff takes just under 4 qts
Trans case takes 2 qts ATF or 3 Qts 5W-30
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 11-05-2009, 10:55 AM   eBay Motors   #3 (permalink)
Follmer
Follmer's Avatar
Brake fluid ?
Thanks a bunch!
-Josh
2004 2500 LB7
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
Old 11-05-2009, 01:14 PM   eBay Motors   #4 (permalink)
K9Duramax
K9Duramax's Avatar
what are you switching to for fluids?
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is online now   Reply With Quote
Old 11-05-2009, 08:51 PM   eBay Motors   #5 (permalink)
Follmer
Follmer's Avatar
All schaeffers
-Josh
2004 2500 LB7
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
Old 11-05-2009, 08:58 PM   eBay Motors   #6 (permalink)
Big H
Big H's Avatar
^^^^^ Good Choice!!
07' GMC 2500 SLT C/C 4x4 Classic
Reunel Front Bumper
Resonater Plugged
4" MBRP Turbo Back SS Exhaust
S&B Cold Air Intake
B&W Turnover Ball Hitch
DMI Spring Cushioned Receiver Hitch
Big H is offline   Reply With Quote
Old 11-05-2009, 09:08 PM   eBay Motors   #7 (permalink)
Follmer
Follmer's Avatar
Originally Posted by Big H View Post
^^^^^ Good Choice!!
I know. I have had nothing but success with Schaeffers. Im sold on it and seriously believe in there product
-Josh
2004 2500 LB7
Fass 95 GPH
S&B Intake
MBRP 4 inch
Suncoast Stage IV
Boost Valve
Tie Rod Sleeves
