Old 11-18-2009, 11:26 AM   eBay Motors   #1 (permalink)
p1093 limp mode stock truck
hey, i'm workin on a 05 lly for my buddy and i just plugged efi to it and read the codes. i got p1093 the low rail pressure code. my problem is i aint sure were to start ,the fuel filter is changed every oil change and unless it collapsed it should be fine. i'm wondering if it could be a faulty or weak regulater or cp3. or if it's intermidiat electrical. the code was set at 58 mph boosting 31 psi pulling loaded bed of tools and bobcat. so it was in a pickle when it drained the rail which is what i expected but why is a stock truck with clean filter running out of fuel. any help will be greatly appreciated. thanks sorry bout my spelling!
MASTERSON1172 is offline   Reply With Quote
Old 11-18-2009, 01:11 PM   eBay Motors   #2 (permalink)
IdahoRob's Avatar
Even stock LLY's had FPRV problems. Most likely shimming the fuel pressure relief valve will fix it.
1093's are caused by fuel restriction before the cp3, or weak relief valve.
2007 LBZ Daily driver, stock engine 11.70 @ 115mph on #2, 677 HP, MPI Twins
2002 LB7 Max'd Out 9.801@139+MPH on #2 fuel only, MPI Twins
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 11-20-2009, 01:09 AM   eBay Motors   #3 (permalink)
Thank you sir, I'm glad to hear your input you know these trucks very well, I was looking forward to your input in particular more than anyones. I always fill confident in taking your advice. i will replace the fuel filter again to start fresh and then shim the FPRV. Thanks Again
Old 11-21-2009, 08:17 PM   eBay Motors   #4 (permalink)
FoX BoX RaCiNG's Avatar
Bump for an honest guy
05 Sierra LLY, TDBDog w/Outlook, BDog 2 pin shift kit, aFe 4" turbo back exhaust, Ford 2" key lift, 33x12.5 TrXuS on White trash Steelies
FoX BoX RaCiNG is offline   Reply With Quote
