Old 11-19-2009, 07:02 PM   eBay Motors  #1 (permalink)
05 LLY timing cover seal
I am replacing the timing cover & crank seal. The question I have is how do I replace the metal sleeve that the seal rides on. Do I need to replace the sleeve, it shows no visible wear. Thanks for the help Rex:
rexp is offline   Reply With Quote
Old 11-20-2009, 10:47 AM   eBay Motors  #2 (permalink)
lostscout's Avatar
you shouldn't have to replace the sleeve if there is no heavy wear mark
lostscout--06 Sierra CCSB LBZ D/A (named Ironhorse) Pewter all stock owned since June09
Semper Im Excreta, Solum Profundum Variat---always in shite--only the depth varies
**AMSOIL thanx to MRMANNERS**
lostscout is offline   Reply With Quote
Old 11-21-2009, 03:38 PM   eBay Motors  #3 (permalink)
Thanks
I ended borrowing the G.M. installation tool it is pretty cool you install both at the same time. Thanks for the help Rex
