04.5-05 LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
in 5th gear, i have limped my trans once and of course I was cruising on the interstate gave it just a little more foot and limped it in 5th just take it easy in overdrive and downshift like chris said if you want to hammer on it
__________________ Eric: 2005 GMC 2500HD LLY
All men are created equal, then a few become firemen.--Unknown Author
It's a man's obligation to stick his boneration in a women's separation; this sort of penetration will increase the population of the younger generation.
Limp mode is when there is something that goes wrong like when the clutches slip from to much power in this case the tcm picks up on it and so it doesnt continue to happen and hurt the trans it puts it into limp mode which limits you and your RPM's to like 3rd gear i believe, usually you will get an engine light telling you that the TCM threw a code the light can either be reset with a tuner or should go off with a few key cycles... But the truck has to totally be shut off, and restarted to take the trans out limp mode.... And people say if you limp your trans once it gets a little easier to limp after that for everytime it happens
The trans goes into "Safe Mode" and limits rpms, speed and fuel. You will get a p07xx code as well. I smoked my torque converter in 8,000 miles with PPE 225 but never limped it once.
__________________ 06 Chevy LBZ/Allison 4x4 EFILive & DSP5, Suncoast IV w/1054, Suncoast Tcase brace, MA pump rub fix, PPE lift pump, AEM Intake, shimmed fprv, ported rail fittings, 4"-5" Grandrock/MBRP, torsion bolts removed, 4" drop shackles, stock turbo, stock wheels, Autometer GS boost/pyro, Aeroforce scangauge, PPE sleeves, Cognito pitman/idler braces, 8k HIDs, Recon LED tails & smoked 3rd brake, Pioneer DVD, 98,000 miles and counting 12.60 @ 105.41 mph #15---Top 25 Fastest Stock Duramax's Keystone 8 Luggers Videos
SO if I crank it up to 3 just stay out of it on the highway and I'll be alright ?
im hard as hell on it in the 3rd setting...all the way up to 125mph
__________________ -Lonny, 18 "Its not all about the size of the tire, its about the traction in action"
2002:
K&N intake(switching to Banks or S&B)
MBRP Turbo-Back (Black)5", PPE Hot+2
Thanks to Tyler @ MPFwww.meyerperformance.com
