Question on codes p0202 and p2149 - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 12-05-2009, 01:07 PM Thread Starter
Hi got a 05 3500 running really ruff and throwing 2 codes p0202. And p2149 any ideas
042500hd is offline
post #2 of 5 (permalink) Old 12-05-2009, 08:58 PM
DuraMac's Avatar
Send a message via AIM to DuraMac Send a message via Yahoo to DuraMac Send a message via Skype™ to DuraMac
P0202:
Number #2 injector Drive fault, incorrect current on a fuel injector circuit (the condition exists for less than 1 second)... you should have freeze frame data with this one (operating conditions). The control module will disable the fuel injector with the concern. that'll be why it's running so rough. 2149 is a sister code set with it. Seems like the 2149 code is set to show the "set" of injectors will be disabled.. that is 4 cylinders that belong to your failed injector #2 so it probably shut down #3, #5 and #8 as well. It will turn off the lamp if the problem does not occur after 3 warm up cycles and drop from history if you have no issues for 40 warm up cycles. That's if it actually come right in the first place I guess!
DMax BLACK '05 LS CC LB @ 100K miles, factory 2" lift, HID's
Banks Economind, IQ, Intake, SpeedBrake, Boost Tube, Monster Exhaust
Other AFE MP, Amsoil & Bypass, Ameriguard spray-in liner, Leer Cap, Bed Rack, Bug Guard, Inverter.
Crap Iron Cross Automotive Nerf Bars - NOT RECOMMENDED!!
Helpful Helm GM Service Manuals - like... 9000 pages!!
Rescue VHF Radio, Jotto Desk Laptop command center, Rescue Gear, Lotsa Flashy LED's, Shinny Decals
Haulin B&W Turn Over Ball & Companion, Firestone Ride-Rite Air Lift Bags, '14 Heartland Warrior Toy Hauler, (12000lb dry), Kayaks, Harley
DuraMac is offline
post #3 of 5 (permalink) Old 12-06-2009, 07:57 AM
Administrator
jc1843's Avatar
The cheap fix is to use "Ice Pick" the injector connector-common problem!
I wrote this and saved it--That problem is usually caused by a loose connector at the injector. The cheap fix that will last, is to remove the connector, place it against something flat, and push a SHARP ice pick into both terminals. This will raise a dimple inside the connector for a better contact. Do this for #2 and #7 injectors. (The cylinders are numbered from the front--- passenger side- 1-3-5-7 and the drivers side is 2-4-6-8)
Also inspect the FICM harness at the alternator for shorts and wear-through. The harness is tied down with a zip tie, gets cut and shorts by contact with the sharp corner of the bracket.
These are common problems for the LLY engine. Everyone that has a LLY should know how to do this, and have a sharp ice pick in the glove box!
jc1843 is offline
post #4 of 5 (permalink) Old 06-07-2014, 05:38 AM
push a SHARP ice pick into both terminals--- Do you mean from the side of the connector or from the top of the connector.
When i disconnect the battery and reset the ECM it runs good for some time after driving for some time the problem returns. I am wondering if the injector is bad it should be a hard code and the check engine light should come on as soon as i start the vehicle. Any suggestions will be appreciated.
advanceauto is offline
post #5 of 5 (permalink) Old 06-07-2014, 06:39 AM
Administrator
jc1843's Avatar
FICM uses 2 separate circuits (banks) to fire the injectors.
If the wiring for any of the 4 injectors is compromised, all those cylinders will shut down and set code 2146--- or 2149.
Bank 1 => 1,4,6,7
Bank 2 => 2,3,5,8
It is NOT the injector-! GM has a repair connector-- also some part stores.
jc1843 is offline
