LLY injector leak - Chevy and GMC Duramax Diesel Forum
Old 12-07-2009, 05:38 PM   eBay Motors  #1 (permalink)
T.I.'s Avatar
LLY injector leak
Alright so I just drove from Kansas to Arizona and during the trip I started to smell more of a diesel smell in the cab and also when I would stop and fuel. When I got home I found that the metal sleeve from the fuel line going into the injector on #8 had a small leak at the base. Nothing major but enough to make the side of the motor wet. Is this an injector problem or is there an o-ring in that sleeve connecting to the injector??
Thanks in advance.
2005 LLY 4x4 CC/SB 6" RCD lift Bilstein 5100's 315/70/17's BFG AT/TA. Kenwood DVD/Navi. Res cap. Air box mod. LBZ MP 5" MBRP TB
T.I. is offline   Reply With Quote
Old 12-07-2009, 05:50 PM   eBay Motors  #2 (permalink)
05lly2500hd's Avatar
by sleeve, you mean the fuel line where it connects I assume..? sure it's tight?, no o-ring that I know of. grab a 17mm wrench and make sure it's tight.
GRIM REAPER DURAMAX, "BRODY" EDITION
05 Duramax LLY, 4wd, crewcab, LT, black and debadged, BMS/Burkhard built LLY with Howard's Xtreme Duty rods, cam/crank pin fix,cut pistons, DPR HV oil pump, ARP head studs, MPI twins, SCIII/1050,MBRP 4" straight, EFILive by Rob,Rear diff upgrade from Tony, 18" Gear Alloy Double Pumps on 285 Nitto Terra Grapplers,Rhino lined, SD tie rod sleeves, 5% tint all around, Kennedy dual pumps/pickup, Optima battery, Autometer C2 60 boost/1600 pyro/100 oil on a-pillar, ATP spring clamps, Fumoto, Bilsteins
NRA/GOA/TSRA
05lly2500hd is offline   Reply With Quote
Old 12-07-2009, 05:54 PM   eBay Motors  #3 (permalink)
T.I.'s Avatar
Yes from the fuel line. It is tight. First thing I checked.
Old 12-07-2009, 06:05 PM   eBay Motors  #4 (permalink)
if the injector is down and tight, it may be the o-ring on the injector??????????
I had a small fuel "leak" on #8, matter of fact, and it was the o-ring on the injector, had to replace o-ring and washer.
There was a TON of carbon build up on injector body as well.
NRA/GOA/TSRA
Old 12-08-2009, 04:56 PM   eBay Motors  #5 (permalink)
T.I.'s Avatar
Did you have to remove the injector??
Old 12-08-2009, 05:04 PM   eBay Motors  #6 (permalink)
yea, it was a pain but not TOO bad.
NRA/GOA/TSRA
Old 12-08-2009, 05:09 PM   eBay Motors  #7 (permalink)
T.I.'s Avatar
Does anything else need to be removed to get the injector out??
