Not running right! - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 26 (permalink) Old 12-28-2009, 03:42 PM Thread Starter
The treatment I used was Howes (spelling may be wrong). The first time It started to gell I put 911 in it, and after that tank was gone I started putting in the howes.
2007.5 LMM
Mac219 is offline
post #12 of 26 (permalink) Old 12-28-2009, 03:43 PM Thread Starter
It is the oil type
2007.5 LMM
Mac219 is offline
post #13 of 26 (permalink) Old 12-28-2009, 03:45 PM
Take that POS out of the truck and throw it in the garbage. small amounts of oil make there way into the air stream and it lands on the MAF sensor. Take the MAF out and cleant it with MAF cleaner.
Phil
2012 6.7 Powerstroke.
samdweezel05 is offline
post #14 of 26 (permalink) Old 12-28-2009, 03:57 PM Thread Starter
Thanks,
Why would this all of a sudden do that? And if it was a "air" issue, wouldn't that cause it to smoke more?
2007.5 LMM
Mac219 is offline
post #15 of 26 (permalink) Old 12-28-2009, 03:59 PM
Originally Posted by Mac219 View Post
Thanks,
Just the opposite. The MAF is covered with junk so it doesn't think there is enough air so it doesn't add lots of fuel no matter how hard you press the go pedal. These trucks are pretty smart. Maby a little too smart.
Phil
post #16 of 26 (permalink) Old 12-28-2009, 04:06 PM Thread Starter
ok thanks alot, I will try it
2007.5 LMM
Mac219 is offline
post #17 of 26 (permalink) Old 12-28-2009, 04:24 PM
x MadMAX DIESEL's Avatar
I'm sure the lack of smoke is just from the cold dense air
x MadMAX DIESEL is offline
post #18 of 26 (permalink) Old 12-28-2009, 04:35 PM Thread Starter
If I clean the MAF sensor and it doesn't fix it, is there anything else I could try?
2007.5 LMM
Mac219 is offline
post #19 of 26 (permalink) Old 12-28-2009, 04:36 PM Thread Starter
it was actually still smoking alot that morning that it started doing it. I think its prob gonna be the maf sensor. When I got stuck the front end was pretty jammed with snow, probably sucked some stuff up
2007.5 LMM
Mac219 is offline
post #20 of 26 (permalink) Old 12-28-2009, 04:55 PM Thread Starter
What exactly is MAF sensor cleaner?
2007.5 LMM
Mac219 is offline
