Not running right! - Chevy and GMC Duramax Diesel Forum
post #1 of 26 (permalink) Old 12-28-2009, 02:23 PM Thread Starter
Not running right!
Not running right at all. I was driving down the road and noticed that it did not seem to have the power that it normally does. I switch my tune to my tow tune, approx 80 horse, and tried that. It didn't make a bit of difference, in fact it didn't even smoke when it normally does. Its acts as if it is being held back, like a brake is on and it won't let it open up. Keep in mind we have had 10" of snow in the last 2 days and temps have been low. I have put additive in it and thought maybe my fuel filter was dirty. Today I put a new filter in it and it did not help it at all. It still runs fine, but like i said, it don't have the power like it did and it does not smoke hardly at all. The dsp5 seems to be working fine as well. Any suggestions?
2007.5 LMM
Mac219 is offline
post #2 of 26 (permalink) Old 12-28-2009, 02:25 PM Thread Starter
I have also checked the air filter to see if I had sucked it full of snow and it was fine.
2007.5 LMM
Mac219 is offline
post #3 of 26 (permalink) Old 12-28-2009, 02:33 PM
tgreene's Avatar
how cold are we talking because I have seen 10deg f a lot and still havent had any problems and I havent plugged my truck in yet....
Trevor Greene
AMSOIL Dealer
2007 Chevy 2500 HD LBZ,CC,SB
tgreene is offline
post #4 of 26 (permalink) Old 12-28-2009, 02:36 PM Thread Starter
Its been anywhere from -10 to 30, but as far as that, it hasn't had a problem with the cold temps.
2007.5 LMM
Mac219 is offline
post #5 of 26 (permalink) Old 12-28-2009, 02:40 PM
tgreene's Avatar
what treatment did you put in your fuel when you thought is was gelling....
Trevor Greene
AMSOIL Dealer
tgreene is offline
post #6 of 26 (permalink) Old 12-28-2009, 02:41 PM
When was the last time the fuel filter was changed?
Phil
2012 6.7 Powerstroke.
samdweezel05 is offline
post #7 of 26 (permalink) Old 12-28-2009, 02:44 PM
tgreene's Avatar
Come on phil....
Trevor Greene
AMSOIL Dealer
tgreene is offline
post #8 of 26 (permalink) Old 12-28-2009, 03:23 PM
kansas's Avatar
Send a message via Yahoo to kansas
check your air filter and the air filter inlet if stock it may be packed with ice and or snow.
Stock 05 LLY A/T 4x4 CC SB
01 Cummins Dually Quad cab 2WD Straight piped Powermax, built trans and converter.
kansas is offline
post #9 of 26 (permalink) Old 12-28-2009, 03:39 PM Thread Starter
I actually did check the filter today, and it seemed to be ok. It is a K&N intake system. The filter was fine. I did kinda get stuck in some snow, and when I did it got alot of snow up undernieth the front of it (front axle area and above). I cleaned all of it out think something was getting plugged and that didn't help either.
2007.5 LMM
Mac219 is offline
post #10 of 26 (permalink) Old 12-28-2009, 03:42 PM
K&N???? is it the oiled type or the dry type?
Phil
