Hydro Boost leak? - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 12-29-2009, 05:16 PM Thread Starter
crazycrew's Avatar
Hydro Boost leak?
My hydro boost is leaking. Not terrible, but its leaking. It's leaking where the aluminum body that holds the fluid resivoir and black body mate up. Dont know what it's called i'll post a pic. Haven't tried tightening the two bolts yet! Is there just a gasket i can change or do i have to change the whole thing? Any special instructions? I've never messed w/ this before. Do I have to bleed brakes?
BROOKS LANDRY
2003 CCSB 2wd
My New Project
Instagram: brolandry
One Big Ass Mistake America
U Can't Cure Stupid
Shop @ the DMAXstore.com
crazycrew is offline
post #2 of 9 (permalink) Old 12-30-2009, 04:29 PM Thread Starter
crazycrew's Avatar
No One?????
BROOKS LANDRY
2003 CCSB 2wd
My New Project
U Can't Cure Stupid
post #3 of 9 (permalink) Old 12-31-2009, 05:33 AM
Not sure how/if theirs a gasket but get on that fairly quick...if that bad boy goes so do your brakes...which I'm sure you already know. Just being the worried momma
2005 Chevy 3500 4x4 DRW CC/Alli...LBZ MP, PCV ReRoute, Hacked-Up Airbox (Thanks KennedyDiesel for the Freebie!) PPE Standard, EGR Blocked, 4" MBRP Turbo Back exhaust, AutoMeter Boost & EGT Gauges, Cognito Brace, Bilstein 5100's
1969 Dodge SuperBee 500 cu in ('tis fun)
1965 Plymouth Max Wedge (9.35 1/4 miler
Project: 70' 440-6BBL 'Cuda (real deal....about 2 years out)
99' Mustang GT- All built, Dynoed 514 RWHP at 13 lbs Boost
Barracuda is offline
post #4 of 9 (permalink) Old 12-31-2009, 05:50 AM
mijdirtyjeep's Avatar
I do not think you can easily just replace a gasket. Usually if they are leaking there it is time to replace the unit.
Jim
mijdirtyjeep is offline
post #5 of 9 (permalink) Old 12-31-2009, 06:03 AM
LHN...We ARE the Joneses
Originally Posted by crazycrew View Post
No One?????
No, there is no gasket and the bolts aren’t loose. You need to replace the Hydro-Boost unit. Easy stuff, and no need to get into the brake system. Get the part ordered (see below) and keep an eye on the PS reservoir…don’t let it run dry.
Remove the nuts on the two studs, and push the Master Cylinder forward to clear the studs. There’s enough flex in the tubing to do so. Remove the high-pressure lines (with fittings) on the HB unit, along with the low-pressure return line (hose clamp). This line will be stuck, just twist left and right to break the seal and remove. Use caution when pulling that line off, you’re wrist will inevitably strike the metal support on the firewall and slice you open.
On the inside, remove the keeper for the push rod attached to the brake pedal. Remove the four nuts from the studs and pull the unit out from the engine side. Installation is reverse and the unit is self-priming. However, you should flush the system to start anew and add this to your regular maintenance schedule to prolong the life of the system components.
Power Steering/Hydro-Boost Flush
Chances are, had this been done on a regular basis, you wouldn't be out $300 for the repair. The fluid is easily torched and loses viscosity, wearing the piston and causing the seals to eventually leak.
The GM part number is 15854059, available from gmpartsdirect.com
GM PART # 15854059
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $543.74
OUR PRICE: $282.85
Hook'em_Horns! is online now
post #6 of 9 (permalink) Old 12-31-2009, 06:13 AM
Administrator
jc1843's Avatar
Leak
If it is leaking oily fluid, it is the Hydro unit. However, if it is leaking brake fluid, it will be the seals in the mastercylinder.
It is best to replace these with new parts and not trying to rebuild, or install a used unit.
You can tell the difference-- place a little on your finger and try to wash it off with water only- brake fluid will wash off- Hydro fluid will not, without soap.
jc1843 is online now
post #7 of 9 (permalink) Old 03-16-2010, 12:19 AM
ARM
Ronan is offline
post #8 of 9 (permalink) Old 02-21-2011, 09:07 AM
hummertastars's Avatar
Same part number for an 02?
2002 CHEVY CREW CAB 2500 6.6 DURMAX :rockin
I refuse to tip toe through life to arrive safely at death
hummertastars is offline
post #9 of 9 (permalink) Old 02-08-2013, 06:10 AM
2Lane Racer's Avatar
What about using aftermarket hb unit? Cardon and Wagner both make replacement units that can be had for less. How are these units conpared to factory replacement?
Lane
92 3500 DRW single cab, NV4500, 3.73, 190,000 on truck, 15,000 on rebuild. Diamond Eye 3" to 4" straight pipe.
02 2500HD Allison CC LWB 4x4 171,000
Just installed its 3rd set of injectors, efi live with dsp5 switch, much more to be done...
09 Silverado CC gasser 132,000
SOLD
2Lane Racer is offline
