P0202 & P2149??? Need Help Guys! - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 12-31-2009, 02:20 PM Thread Starter
southcaliboy's Avatar
Send a message via Yahoo to southcaliboy
Quick rundown,
2004, pretty sure it is a LLY. Just hit 81,000 miles.
I noticed a slight knocking sound over the last few months only around 1300 to 1600 rpm and very mild, but noticeable.
I went out the other night, started it and heard a LOT of knocking. Check enginge light came on of course and I shut her down, and proceeded to do a underhood inspection for anything obvious. I noticed that there is a wicking type of oil buildup all around the MP to the turbo. Any ideas there would be greatly appreciated, though the knocking and codes are my main concern as of the moment.
Started the truck again, ran normal, did not throw check engine light.
After letting it sit overnight I tried once more. Hard knocking, constant check engine light.
Pulled codes
P0202 (injector circuit, open cylinder #2)
P2149 (fuel injection group B supply, injection circuit open)
I am now at a standstill and do not know what to do from this point on. I have a good mechanical background, but I am not going to claim to know anything about diesel engines.
I called a dealership out here in Southern Cali, and they told me that there was only a 7 year, 70,000 on this vehicle, a deisel mechanic told me that they may have been wrong??
Any help would be greatly appreciated.
Sincerely,
T.W.
southcaliboy is offline
post #2 of 9 (permalink) Old 12-31-2009, 02:27 PM
ALLY Cat's Avatar
Sounds like the famous injector harness failure that affects #2 and #7 connectors on LLYs. Search "icepick" for a temp quick fix. I'm sure others will shed more light, one of LLY weak points but easy to fix.
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, trans by Mike L, Magnaflow DP, Ride Rites, LBZ turbo inlet mod, AD II 165, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is offline
post #3 of 9 (permalink) Old 12-31-2009, 04:17 PM Thread Starter
Do i search "icepick" here on the site or on the web?? I appreciate that peice of advice by the way, is it a quick fix that I will be able to make myself ?
post #4 of 9 (permalink) Old 12-31-2009, 04:38 PM Thread Starter
Where is the #2 injector? Passenger side or Driver side?
For the "Icepick" trick, do I pick the injector pin directly or the E.C.M pin?
Where is the #7 injector?
Does anyone know what the harness kit cost for repair?
Thanks fellas.
T.W.
post #5 of 9 (permalink) Old 12-31-2009, 04:56 PM Thread Starter
Okay,
I removed the #2 injector connection, wiggled it around to see if a movement of connections would show me whether or not I was on the right track and it solved the problem as you fellas mentioned.
Now I need to make the fix, icepicks are pretty big from what I remember LOL. That harness connector is pretty dam small where the wires input and the icepick would cross through. What are you guys using to drive through the connector over the top of the wires for compression??
post #6 of 9 (permalink) Old 12-31-2009, 09:48 PM
ALLY Cat's Avatar
I'm surprised nobody else chimed in here, maybe they're all celebrating or something? I haven't had to try the icepick yet since I've never had a problem, I'm planning on extracting the connector sockets, placing a slightly smaller drill blank inside and making some dimples with an automatic center punch. I have heard that just cleaning them with a pipe cleaner periodically works too. These circuits switch about 13 amps, pins look pretty small for the task. I believe GM has a repair kit for this since there's a TSB on it. Seems like I've herd the repair kit is something like $400 or more. Keep searching, there's a lot written about this problem, also more on the Diesel Place forum too. Let me know how you fare on this.
ALLY Cat is offline
post #7 of 9 (permalink) Old 01-01-2010, 01:49 AM Thread Starter
Thanks Ally Cat, Happy New Year.
I will keep you up too date.
If there are anymore opinions out there the ywould be greatly appreciated.
Sincerely,
T.W.
post #8 of 9 (permalink) Old 01-01-2010, 07:36 AM
Administrator
jc1843's Avatar
Many have had the GM "fix" done on their trucks and then had it fail again. If the "Ice Pick" fix is done right, it will last!
jc1843 is offline
post #9 of 9 (permalink) Old 01-02-2010, 12:51 AM Thread Starter
Well guys,
I ended up removing injector connection by injector connection and cleaning them all. I just did a simple clean with some CRC component cleaner and really mainly found the #2 and #7 connector to have accumulated the most dirt and or grime though mainly dry but nonetheless a cause for bad conductivity.
#2 connection is right next to the power steering pump and therefore I see that being a main issue for injector connector issues.
#7 seems to catch all the blowback produced by the cooling system and the turbo and intake sysetm, though it was very dry with only a golden brown accumulation.
Truck is running great now along with the absence of that horrible piston slap sound when a injector does not allow for combustion lmao! It is no longer throwing any codes. Time will tell but after a good long drive I am somewhat confident that the issue is resolved.
Thank you all for the comments and ideas, I did purchase a Scratch Awl that I will be keeping in the glovebox, I did not use the "Icepick" technique. I do fully understand it and now that I know that the connections are very clean, if the problem occurs again #2 will be gettin a nice poking from me!
Happy New Years to all!
Sincerely,
T.W
