Fan clutch assembly removal - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 01-12-2010, 12:32 PM Thread Starter
GMfaith6.6's Avatar
belt broke and took out several fan blades. wish to replace, cant seem to get the fan clutch off, left or right hand thread? also do you need special tool or can you use strap wrench? seems to spin with the belt assembley
GMfaith6.6 is offline
post #2 of 20 (permalink) Old 01-12-2010, 12:42 PM
vaughninms's Avatar
If I remember correctly, it is left thread. [Right hand thread] The easiest way to get it off is using an air punch (or chisel if you don't have a punch). A two or three second blast on the edge of the nut will get her loose and it will spin off after that. Reverse the process to put it back on. Hope this helps.
GOD BLESS OUR TROOPS SERVING HERE AND ABROAD!!!!
1997 Chevy Tahoe 4WD, 4Door 5.7 Vortec w/ 327K on original engine- Still going strong - Bone stock except for new Jasper transmission.
2005 GMC HD2500 LLY CCSB w/ 150K BFG 265/75R16
KillerBee's IOH Kit and TCAI. http://killerbeeperformance.com/ Black Nerf Bars. Curt Hide-a-ball gooseneck hitch
4" MBRP Downpipe back w/ Magnaflow muffler & 5" tip - Thanks Tyler! www.meyerperformance.com
Combo 75 Gal Transfer tank w/ 15 GPM pump and toolbox
vaughninms is offline
post #3 of 20 (permalink) Old 01-12-2010, 01:09 PM
Administrator
jc1843's Avatar
It is right hand normal threads--
The pulley has a couple holes to place a spanner wrench. As stated aair chisel is the best to try to unscrew the threads.
jc1843 is online now
post #4 of 20 (permalink) Old 01-12-2010, 01:21 PM
vaughninms's Avatar
My bad on the thread direction. It was back in the summer when I took the fan clutch off. Thanks for the correction.
post #5 of 20 (permalink) Old 01-13-2010, 10:26 PM
Tow Master's Avatar
There is a spacial tool you need to remove it. A air chisel will work as well.
Most auto parts stores like advanced will have them for rent.
GM G.M. Waterpump Hub Holder Fan Clutch Wrench Tools:eBay Motors (item 170431508501 end time Feb-11-10 09:38:55 PST)
Jason
Tow Master is offline
post #6 of 20 (permalink) Old 01-13-2010, 10:31 PM
SDP
Scott@SDP's Avatar
I used a small spanner wrench and large crescent wrench, took a bit of yarding on it to finally break it loose with the 105k miles it had on it but it did the job.
Screamin Diesel Performance 360-417-9000 Scott@SDPtwins.com
Compound twin turbo kits with 3" y-bridge and coolant tank for all Duramax's
SDPtwins.com LIKE US ON FACEBOOK!
2016 2.8L Duramax Canyon with SDP Compound twin turbo kit and DSP4 tuning
2009 LMM SDP trans, SDP GT5541/GTX42 twins, 200% injectors, 2x Exergy CP3's, Socal motor, ATP tuned
2002 LB7 SDP twins, ATP tuned, stock motor 11.97@113mph 7,200lbs
2001 LB7 SDP Built transmission, Single SDP S475, ATP tuning
2006 LBZ Race truck build
Scott@SDP is offline
post #7 of 20 (permalink) Old 01-14-2010, 07:55 AM
IdahoRob's Avatar
Pipe wrench and a hammer. Sharp blow and spin it off.
2007 LBZ tow rig/Daily driver, stock engine 11.70 @ 115mph on #2, 677 HP, MPI Twins
2002 LB7 Max'd Out 9.71@141+MPH on #2 fuel only, MPI Twins
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline
post #8 of 20 (permalink) Old 07-09-2012, 05:04 PM
smacker86's Avatar
old thead but i have another ?. I've taking the fan clutch off my 01 twice, once when i replaced flexplate, and another when i did the fpr.. And i cant remember which way to turn the darn nut.. the fan moves counter clockwise while looking from the front of the motor, so ive been trying to turn it clockwise. both times it came off pretty easy with the fan clutch holder, i just stick little bolts in the pulley and use that and a piece of steel i made to fit on the nut.. theres a little 3/8 coolant line that is leaking that connects to the pipe that goes from the thermostat housing to the pump and some other line and was hoping that i could replace it without taking that pipe off.
2001 chevy 4x4 Regular Cab LB7...5inch exhaust(not MBRP!!) Profab intake horn and downpipe,Rare parts tie rods,Cognito Braces,Coolant filter,Nicktane,Airdog100,Pump rub fixed.diy high idle mod.Rear Airbags..................R.I.P.-2006 Chevy 2500 4x4.Regular Cab 4x4 LBZ
smacker86 is offline
post #9 of 20 (permalink) Old 07-10-2012, 05:58 AM
smacker86's Avatar
Nm i got it off, was turning it the wrong way..going to put an arrow of the tool for next time
post #10 of 20 (permalink) Old 07-10-2012, 06:15 AM
Administrator
jc1843's Avatar
Easy way to remember-- it unscrews the oposite way it normally turns.
If it was left hand-- it could come off when you drive the vehicle.
