how to relearn vane sensor - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 01-22-2010, 05:52 PM Thread Starter
alright i put in the mp yesterday night and now ive got codes p0045 & 46. read it said i may need to rrecalibrate the vane sensor. question is, how do i do it????? im using a snap-on verus. any ideas????? can i even do it with the verus or do i have to go to the dealer????
'04.5 2500 HD Ext Cab LT
1/4 million+ mile mark
19 mpg @ 65mph
*Rhino liner
*LBZ MP installed 21 mpg @ 65mph
*PCV reroute
*MBRP 4" turbo back exhaust
davidsua04 is offline
post #2 of 19 (permalink) Old 01-22-2010, 06:07 PM
jbrown1132's Avatar
i'm not aware that the vane sensor could be recalibrated. i believe if you have a faulty sensor, it must be replaced.
'05 GMC 2500HD (white) slt cc sb 4x4
efi-tuned by idahorob, egr blocked, pcv rerouted, lift pump, kodiac mp,autometer sportcomp gauges, turbo dp, 4" ss magna flow exhaust straight piped, firestone ab, kool-vue towing mirrors, 5th wheel hitch with slider, gooseneck hitch.
305 MT ATZ's on eagle alloy 17x10
jbrown1132@yahoo.com
alligatorperformance.com
atptrucks.com
Truck is sold....
jbrown1132 is offline
post #3 of 19 (permalink) Old 01-22-2010, 06:09 PM
duratothemax's Avatar
you might actually need a tech 2. Many times the snapon/mac scan tools dont do the procedures correctly.
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #4 of 19 (permalink) Old 01-22-2010, 06:17 PM Thread Starter
this is what the verus says for code p0046..... alot of typing....
"position of the turbocharger vanes is controlled by the ECM. ECM utilizes a turbo vane control solenoid and a turbo vane position sensor to control the turbo vanes. when engine is not under load, the turbo vanes are in an open position, or no boost condition. when engine is under load, the ECM commands the Control solenoid valve to close the trubo vanes. thus increasing the boost. ECM will vary the boost dependant upon the load requirements of the engine. the Vane control solenoid control valve uses 2 circuits, a control circuit and a low reference circuit. ECM uses a pulse width modulation on the control circuit to open and control the solenoid valve.
if any service has been performed on the turbocharger or on the turbocharger components, a turbocharger relearn must be performed. failure to perform relearn may cause this DTC to set."
mine my fingers are tired. lol
19 mpg @ 65mph
*Rhino liner
*PCV reroute
post #5 of 19 (permalink) Old 01-22-2010, 06:57 PM
Banned
relearn procedure with a tech II.
You need to see a dealer or someone with a tech II.
This is common.
MMLMM is offline
post #6 of 19 (permalink) Old 01-22-2010, 07:01 PM
Slave to the Interwebs
Johnasara's Avatar
Just out of curiousity can you do this with EFI???
Johnasara is offline
post #7 of 19 (permalink) Old 01-22-2010, 07:11 PM Thread Starter
MMLMM, so you think the vane sensor or some other turbo solenoid didnt magically go out when i put the new MP on??????
19 mpg @ 65mph
*Rhino liner
*PCV reroute
post #8 of 19 (permalink) Old 01-22-2010, 07:19 PM
Banned
No, tech II only.
I kinda read fast....
Thats odd. Are you running a After Market intake too?
I dont think the sensor is bad. And I am not 100% sure the re-cal will fix it either. If you have an aftermarket intake you may need to rescale the MAF.
MMLMM is offline
post #9 of 19 (permalink) Old 01-22-2010, 07:59 PM
Are you sure that you plugged your turbo sensor back in? There are a few that have put the MP on & unplugged the turbo sensor & forget about it.
New Truck
2006 LBZ CC/SB
Full Built Motor
Dual Fuelers,100%exergy sticks
AirDog 200 Pump
Twins 66/88
Tuned by ATP (Rob)
Caltracs
and a bunch of other stuff:
bmos37 is offline
post #10 of 19 (permalink) Old 01-22-2010, 08:43 PM Thread Starter
stock intake, well, cut now witha 4" coupler from lowes(for the next couple weeks)
yea, i double checked it, once when i installed it and again during my lunch hour, i found the clip for the plug had broken so i ziptied the connector together.
19 mpg @ 65mph
*Rhino liner
*PCV reroute
