LLY or LB7 + EGT reading at idle - Chevy and GMC Duramax Diesel Forum
Old 02-05-2010, 03:48 AM   eBay Motors  #1 (permalink)
How do I know if I have an LLY or LB7? My truck is an 04 2500HD silverado and i'm not sure which engine I have.
Second question is What are "normal" EGT readings for "normal" driving?
Third, What should the EGT be at idle?
Forth, is the EGT supposed to rise and fall with the amount of throttle being applied just like A/F does on gasoline engines?
Sorry for all the questions but I just want to make sure that my EGT readings are correct and normal. I know NOTHING about diesels.
TIA!
RICE POLICE is offline   Reply With Quote
Old 02-05-2010, 05:08 AM   eBay Motors  #2 (permalink)
mijdirtyjeep's Avatar
8th digit is either a 1 "LB7" or a 2 "LLY"
Depending on outside temp, and speed. At 2k rpms around 6-650deg
Mine will get up to around 280-300deg
Yes, the more throttle, the more fuel you are dumping in resulting in higher EGT's
TIA!
Jim
mijdirtyjeep is offline   Reply With Quote
Old 02-05-2010, 06:11 AM   eBay Motors  #3 (permalink)
JustinD's Avatar
Idling I can see as low as 190* and the reading at speed will depend on the tune or tuner you are using. Mine will see 1800* on the throttle heavy!!!!!
2001 Chevy ECSB
SCIV 1056 MBRP 4" Kennedy lift pumps EFI live by Jeff Toman. Industrial Injection Silver Bullet 66.
12.65 @ 105 stock charger
494/956 stock charger
523/1084 something is wrong.
www.extremeprejudiceracing.com
JustinD is offline   Reply With Quote
Old 02-05-2010, 10:57 AM   eBay Motors  #4 (permalink)
awsome! Thanks guys.. Yeah, I think i have a faulty egt probe. When I sit at idle the egt rises to about 1300 just sitting there but when I drive around it rises and falls like I would assume is normal. But either way 1300 at idle isn't a good thing lol
Old 02-06-2010, 01:57 AM   eBay Motors  #5 (permalink)
Called Edge and they said it's more then likely the probe so i'm gonna get a new one and see if it fixes the erroneous EGT readings...
Old 02-08-2010, 04:46 AM   eBay Motors  #6 (permalink)
Killerbee's Avatar
1300 at idle is a bad reading.
Generally, more power requires higher EGT. Thermo diesel cycle reference, it is a heat engine.
Michael
Killerbeeperformance.com
