Weep Hole - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 04-12-2010, 10:50 AM Thread Starter
Duramax Forum Moderator
DuramaxOnTheBrain's Avatar
Weep Hole
I'm trying to get a look at the weep hole on my water pump to verify that my coolant leak is coming from there before I tear into it and it ends up being a head gasket.... Where is the best way to view the weep hole? From the top, bottom, can't seem to locate it. A picture would be awesome..... thanks guys!
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline
post #2 of 7 (permalink) Old 04-12-2010, 11:30 AM
duratothemax's Avatar
from the bottom, take off the plastic splash guard.
Its tricky to see, bottom of the water pump behind the radiator hose.
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #3 of 7 (permalink) Old 04-12-2010, 11:36 AM Thread Starter
Thanks a bunch man!
Brian
Kodiak mouthpiece
BUY FROM MPF!!!!!
post #4 of 7 (permalink) Old 04-12-2010, 12:00 PM
1slowdura's Avatar
Send a message via AIM to 1slowdura
I went threw the fender well to see mine. The water pump is easy jus takes some time and the right tools.
1slowdura is offline
post #5 of 7 (permalink) Old 04-12-2010, 01:36 PM Thread Starter
I was able to barely see it from underneath. I pulled the guard back and shined a flashlight up there, it was behind the hose clamp so I had a hard time but finally got an angle on it. I couldn't see any water dripping out but I could see where a trail of water was coming from it and running down to the oil pan so the water pump replacement is a go..... do you guys think I should replace the thermostat while I'm in there?
Brian
Kodiak mouthpiece
BUY FROM MPF!!!!!
post #6 of 7 (permalink) Old 04-12-2010, 11:28 PM
1slowdura's Avatar
yea for sure.I think the thermostat was like 50 bucks make sure you get the right one to
post #7 of 7 (permalink) Old 07-13-2011, 08:10 AM
Water pumps are deceiving. I figured out I need to replace mine after I let it idle and had a buddy shut it off when I was looking at the weep hole. Sure enough, I saw coolant come out of there. Mystery solved after 2 weeks of confusion.
turbohorns is offline
