04.5-05 LLY Duramax PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect
There was no post about the kit not being installed correctly until I posted. That to me sounds like an axe to grind.
I feel badly about your problems, but tell the whole story when explaining failures.
Steve is not a buddy of mine, I've meet him and have talked on the phone many times. I also know MikeL. I'm glad you are working with him and hope you are happy with the end results.
The main line pressure shim adds more holding power to the clucthes than a very small amount. Major part of every trans kit for the allison. Leave it out on a SC stage 5 and see what happens also.
We had three 600HP plus Dmaxs at the drag strip this weekend, all running the complete and properly installed TTS kits. All in the 12's and all working great.
I've been modding my Allisons for 4 years now and testing product. I post about what works.
Take care,
Rob
__________________ 2007 LBZ Daily driver, stock engine 11.70 @ 115mph on #2, 677 HP, MPI Twins
2002 LB7 Max'd Out 9.801@139+MPH on #2 fuel only, MPI Twins
Take care,
Rob
Aparently you know more about a properly built Allison the Mike L because he told me that was not reason for the failure. We all here about your transmission holding huge power on stock clutches, Thats why I bought the kit in the first place because you recomended it to me. What we never hear about is the ATS-CO-PILOT and the other internals helpers you have in your tranny. The TTS kit uses alot of the same components as suncoast but there are a couple other things left out that need to be in there to hold 500whp (DRIVEN HARD) IMO.. For must guys running 500whp that want to run a ricer on occasion or something along those lines the TTS kit with good clutches should be fine. I am no Expert by far but I am learning very quickly who and who not to do buisness with when it comes to my Duramax or Allison.
Way I look at it is, there is no such thing as a perfect product. No matter what you sell, you will always have someone who gets a bad apple. And I've called Suncoast before and asked them about tranny upgrades, and asked them if I bought their biggest kit, with the best options, can they guarantee me that it won't ever limp the tranny. And their reply was no....they won't guarantee it. And I've also seen a couple posts from people who have the full blown 7 grand ATS tranny with Co-pilot who have had alot of issues and limping problems. So I dont' think it matters who you go with....I think it all depends on luck of the draw, and how badly you abuse your truck.
__________________ RIDE: 2007 Chevy CC LBZ / 6 speed LIFT: Ready Lift Leveling Kit STARTER: VIPER 2 Way w/Turbo Timer SOUND:Touchscreen Pioneer P4000DVD/Backup Camera - 6 1/2 Polk Audio everywhere else. ADD ONS: Cowl Hood, 6000K HIDs, Dominator II Steps, BFXenon Grill, ExTang Solid Fold, custom bug shield/vent shades TIRES/WHEELS: 305/70-17 Wrangler MTR Kevlar Tires on 17x9 Liquid Metal Gatlins AIRFLOW: BANKS Monster Dual Exhaust, EGR blocked & CAT removed with MBRP replacment pipe and BANKS Ram Air. PROGRAMMERS: BANKS 6 Gun PDA w/Speed Loader --STACKED-- with Quadzilla Stealth 2
It is a performance part. Performance parts do fail. That's the nature of it. WE all take chances with getting thing upgraded on our trucks. I was nervous as hell getting my SCIV done. I was standing there the whole time thinking am I doing the right thing and I know I did the right thing. My builder did an A-1 job and I watched every step of it. No parts left over! Goodluck with the rebuild.
__________________ 2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
Well my truck did not just go into limp mode it cooked the clutches and would barely move even after I reset the codes.
And yes they will all fail at some point and I agree a good builder goes a long way with any kit. That is why I shoped around and called Suncoast, ATS, and TTS before I purchased a kit. I felt the kit would be sufficient for me and I was mistaking. There are lots of probabilities and I do not want to start a pissing match on here. that is not why I go on these forums I go on here to learn what I can and help where I can. My transmission builder was reffered to me buy suncoast and he has a very successfull buisness, building allisons so between that and my discussions with one of the top Allison guys in the country I have to believe this was a failure do to my abuse while running big tunes and the kit not being able to hold the power. Thats my opinion nothing more nothing less take it for what its worth.
Just wondering custom8726 why did they leave the washer out? What was the reasoning behind it?
__________________ 2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator
The builder should have installed it no matter how little it boosts line pressure every bit helps. After discussing it not be installed with other tranny guys I opted not to make him R&R my transmission for free even though he offered. I do not believe this was the cause of the failure but simply a way to pass the blame.
Ding Ding a way to pass the blame it is. Just because u did not install 1 simple part. Imho u dont need that u increase line pressure enought with the transgo. That washer dont do crap
__________________ Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
Hope you get up and running soon and that you have no more issues.
My last post in this thread is, if the spacer does nothing, tell Mike L. that you don't want it installed again and see how he answers. ATS, Suncoast, and NADP all have the main line valve either shimmed(washer that wasn't installed) or use a different spring to do the same thing.
What about the all important converter flow valve? Was that not installed?
I appears the experienced installer that did your tranny knew how important this shim and boost valve is and that is why he offered to install it for free.
Hope it's up and running soon with many happy miles in front of you!
I'm out of this one,
Rob
