ac problems inside vehilce - Chevy and GMC Duramax Diesel Forum
Old 06-26-2010, 07:39 AM   eBay Motors  #1 (permalink)
Exclamation ac problems inside vehilce
i have 05 lly 4x4 crew lt ac doesnt want to act accordingly..have to turn on and off a couple times..a popping sound is heard when doing this...also would this contribute to skipping at 45 to50 mph...someone told me i could have vaccume leak....i do have k/n cold air,,,4" magnaflow turbo back,,,,,,juice with attitude,,,stock wheels
stewartsav is offline   Reply With Quote
Old 06-26-2010, 08:24 AM   eBay Motors  #2 (permalink)
grizzly5531's Avatar
open your hood and turn the a/c on max or 60 and see if the a/c clutch turns on. if the center of the pulley is spinning then its engaging. there is a low preassure sensor in the ac system right next to the compressor so if you refrigerant level is low the compressor wont turn on
05 GMC Sierra CC/LB Dually
AMP Research steps
4" MBRP to stack
Resonator plugged
Pcv reroute
ALL on mod
7" mitre cut stack
EFILive
14.482 @ 93.93 AUG 13
Stock trans, 2wd and 80psi in the back tires
WT #7350
grizzly5531 is offline   Reply With Quote
Old 06-27-2010, 05:11 AM   eBay Motors  #3 (permalink)
thanks grizzly but the problem is inside the vehicle...outside is fine .
Old 06-27-2010, 06:58 AM   eBay Motors  #4 (permalink)
so the a/c controller isnt staying on or the blower motor or what
AMP Research steps
4" MBRP to stack
Resonator plugged
Pcv reroute
ALL on mod
7" mitre cut stack
EFILive
WT #7350
Old 06-27-2010, 06:43 PM   eBay Motors  #5 (permalink)
someone told me to check the vacumm servos that operate the doors inside the heater box....may have leak and maybe the cause of my other problems
Old 07-10-2010, 06:19 AM   eBay Motors  #6 (permalink)
i have replaced the blower resitor at 145.00 from dealer it solved the problem
Old 08-23-2010, 02:48 PM   eBay Motors  #7 (permalink)
air blend door on mine was not working fixed at dealership.
PBkid is offline   Reply With Quote
