Oil Change 2005 Chevrolet Silverado 2500 6.6 crewcab - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 06-28-2010, 09:56 PM Thread Starter
I have been paying the dealer 80 dollars to change the oil, they recommended every 6000 Miles. I am going to start doing it myself.
I am using dealer oil, anybody know what kind that is?
IS there a better kind to recommend, I don't want to use synthetic?, If I change oil brank, do I just fill it with the different oil or do I need to flush it or something?
How much oil do I need?
What is the recommended oil filter?
How often should I be changing the oil?
Any information is appreciated.
kmontez is offline
post #2 of 25 (permalink) Old 06-28-2010, 11:06 PM
Warlord's Avatar
I change my oil and fuel filter every 5-6,000 miles. I use 10 quarts of Delo 400. I buy three gallons at a time in a box from Costco, and usually purchase my Baldwin oil filter and Parker fuel filter only from Performance Truck Products. He's on this forum, or you can go to their website. Also, there is a bunch of great dealers on here, i just have personally used PTP so that's why i would recommended them. Again, I use Delo, its not a synthetic, just a great heavy duty motor oil that we use in our big trucks so I can't see why it wouldn't be good enough for my pickup. You can get as crazy as you want with oils and synthetics, as for "dealership" oil, I couldn't tell you what it is, I'm sure its something like Delo 400. Hope this helps.
2005 Chevy 2500HD Crewcab 4x4 LLY; 4" MBRP Turbo back; 06 LBZ Mouthpiece and airbox with intake resonator plugged; Predator Programmer set for 45hp 100ft/lbs (tow); ISSPRO Pyro/Boost pillar gauges
B&W turnover ball; Torsion keys and shock extenders-leveled; 285/75/16 BFG All-Terrains
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." -John Stuart Mill
Warlord is offline
post #3 of 25 (permalink) Old 06-29-2010, 01:41 AM
05greendmax's Avatar
80 bucks wow man oil is the easiest thinmg in the world to change 16mm socket and a let it rip and a hell of a grip on the oil filter and ur golden i just change mine with mobil1 delvac for under 35bucks
2005 ccsb hunter green
rip old motor
(fully stock)
motor going in
huge thanks to Dustin and robb at (ATP)
could not have donr this with out your help
hope this new motor holds 500hp this time
05greendmax is offline
post #4 of 25 (permalink) Old 06-29-2010, 01:47 AM
also oil is oil man as long as u buy name brand stuff ur fine they all do the same thing no need to waste ur money on the super expensive stuff if all u do is drive from point a to b if u race ur truck thats one thing but just buy name brand stuff i have ran all that expensive stuff royal purple, amsol, red line, they all do the same thing imo now i buy whatever is on sale .i will say it again oil is oil...........
rip old motor
(fully stock)
motor going in
post #5 of 25 (permalink) Old 06-29-2010, 01:49 AM
tigermack's Avatar
Send a message via AIM to tigermack
The way I see it... if you spent that much for a truck and you want to have it last as long as it should... might as well pay to take care of it. I use Rotella T6 syn. fluid, NAPA gold oil filter. 3 gallons and a filter. You should change fuel filter every other oil change as well, just wanna add that in.
03' EC LB7 2WD
T6 Rotella - Napa oil filter
Amsoil Torque-drive - Napa filter
PPE standard & boost valve | Bilstein 5100's | Prosport EGT & boost gauge w/ Autometer dual overhead pod | Pioneer Avic D3
tigermack is offline
post #6 of 25 (permalink) Old 06-29-2010, 04:50 AM
mrmanners's Avatar
10 qts
If you are staying away from synthetics most use Rotella or Delo. 15W-40 unless you live in a climate that gets extremely cold then you might consider 5W-40 in the winter.
OEM is about 7500 miles
10 qts
mrmanners is online now
post #7 of 25 (permalink) Old 06-29-2010, 10:55 AM
ZX10Aviator's Avatar
I use mobile 1 synthetic, the oil cost about $50, then you gotta get the filter, change it myself. It would be almost $100 to get it changed here at the store.
-SOLD- '05 Sierra Duramax
* Just did HeadGaskets 10-30-2010 * Click for link
-Edge Juice with attidue, AFE Turbo inlet, Rerouted PCV, EGR Blocked and Fingersticked from KennedyDiesel, Grade C HeadGaskets, ARP Head Studs, looking for more mod advice, for longevity and better MPG
ZX10Aviator is offline
post #8 of 25 (permalink) Old 06-29-2010, 03:22 PM
i get mine changed at the dealers at there expense, all i have to do is pay the tax on 90.00 .+ i change it every 3000,because thats when they tell me to come back,lol, they try to sell me a new car every time igo there so i wont be able to get the free oil changes
ebomb is offline
post #9 of 25 (permalink) Old 06-29-2010, 04:07 PM
mwar410's Avatar
I've spent $60 in a filter and oil before, in reality $ 20 for labor is pretty good. from a dealer, they probably lube it also.
GMC 4.5 lly ext cab SLT
EFI live ATP,
4" magnaflow catback, magnaflow down pipe, pcv reroute,nicktane filter adapter, Fuel race valve,duramax tuner LBZ induction kit, BD High flow manifold,SDP full EGR delete w/ LB7 up pipe
Rareparts G2 tierods, rare parts pitman, ultimate idler arm, supersteer idler pivot, cognito UCAs leveled with 315/70/17's, Monomax shocks, energy suspension; body mounts, tranny mount and control arm bushings, and yes it rides like a brick
Cen Pe Co diesel max fuel additive,Cen Pe Co Para/syn oil
mwar410 is offline
post #10 of 25 (permalink) Old 06-30-2010, 12:27 PM
crucescrawler's Avatar
This might be a stupid question... but I'm gonna ask it anyways.
On my buddies 05' to reset the oil life % he says he turns his truck off, puts ignition on, and presses the brake pedal three times and it resets to 100%
Tried it and it doesn't work. How many miles or hours is that 100% based on?
2006 CCLB 4x4 LT LBZ
Rancho Lift, 285's, Cat Back, CTS Insight, Airraid intake.
Near Future: EFI Live (RECOMMENDATIONS?), 5" Straight, PCV reroute, EGR Delete, Cognito Front End...
2005 CCLB 4x4 LT LLY
2" W/ All Cognito Front End. Ranch Hand Legend Full Replacement Front and Rear, Edge Evo CTS, Diamond Eye DP, 5'' MBRP Straight Exhaust. 285/70/17 Nitto's, PCV Rerouted, Resonator Blocked, LBZ Mouthpiece, Modded Air Box and Shroud. Headlight All On Mod
1971 Chevy K-10 LB 350 with a little HP added, Built 700R4, 205 T Case 4" Rancho lift, 33" tires w/ Enkei wheels, Dual Exhaust, 40/20/40 seat, Gas tank out back. www.alligatorperformance.com
crucescrawler is offline
