| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 04.5-05 LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  | |
05-28-2008, 07:03 PM
eBay Motors
#21 (permalink)
| | Member
| never have changed the filter. truck has 40,000 miles on it and ive put around 7,000 on it since i bought it. would i have possibly dameged the turbo on it? |
| Advertisement
05-28-2008, 07:08 PM
eBay Motors
#22 (permalink)
| | DuramaxForum Fanatic
| If you limped your tranny, which it sounds like you did, that means its on the path to destruction. The stock tranny won't hold more than 90 or so hp for very long, runnin more than that is just a time bomb. Best bet is to put it back to stock, and change your tranny fluid and filter and hope for the best. From what everyone on here says, once you limp it, its going to happen again, and more frequently til your tranny is gone. |
05-28-2008, 07:10 PM
eBay Motors
#23 (permalink)
| | BLACKCHAINSMOKN/LBZ
| I would not say turbo just yet,change that fuel filter asap,then you'll know if that's all it was,on such a new truck it's good to get in the habit of proper maintanence,mine has only 43,000 miles,hit me back if ya need help,good filters on fuel system are a must,newer diesels are even more picky,these are not the diesels of even 10 or 15 years ago,I'd bet a 10 dollar bill,ya seeing some fuel flow restrictions,buy the way it sounds,again just goin on what i can understand,clean fuel filters=happy owner...
__________________ 2006 GMC 2500HD4x4 sb cc LBZ!!!  52k
2002 GMC 1500 2wd x-cab-sb 5.3 pwr...
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans
Mods w/LBZ... Full straight piped [no cat,no muff!!]
Superchip Flaspq,res mod/,285M/T tires/
:  Waiting for new JWA,today it should be in!!!We'll see if it works THIS TIME...&^$%#@$*^$%&(^% |
eBay Motors
#24 (permalink)
| | Member
| ok ill try that..thanks for the help |
05-28-2008, 07:12 PM
eBay Motors
#25 (permalink)
| | BLACKCHAINSMOKN/LBZ
| Good luck,lots of knowlegable folks here too,we'll get ya back up..
05-28-2008, 07:20 PM
eBay Motors
#26 (permalink)
| | Junior Member
| what code did it set off |
05-28-2008, 07:36 PM
eBay Motors
#27 (permalink)
| | Member
| when i did a dtc check with my diablo programmer it said no error found. |
05-28-2008, 09:00 PM
eBay Motors
#28 (permalink)
| | Duramax Forum Moderator
| For sure change the fuel filter. It would be my bet that is all thats wrong with it.
__________________ KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan EFI Live Tuned by IdahoRob!!!!
05-28-2008, 10:19 PM
eBay Motors
#29 (permalink)
| | Member
| where is the fuel filter located on the pick up? |
05-28-2008, 11:45 PM
eBay Motors
#30 (permalink)
| | Member
| by the right valve cover back by the heater/ac unit |
| Advertisement
