Old 07-16-2008, 07:22 AM   eBay Motors   #51 (permalink)
luke0490
Points: 398, Level: 6
Points: 398, Level: 6 Points: 398, Level: 6 Points: 398, Level: 6
Activity: 9%
Activity: 9% Activity: 9% Activity: 9%
luke0490's Avatar
Hey guys i thought my problem was fixed but i was wrong. I was pulling my fith wheel while i was following my buddy with his fith wheel and i couldnt keep up with him. Before my ses light came on i could cruise an easy 70 mph with my trailer and i had a hard time keeping it at 60 mph. My buddy has the same year of truck and his is stock and mine has add ons. When going up inclines my buddy was doing and easy 60 mph at about 2200 rpms while i could barely hit 50 mph and i was at 2900 rpms. All this and my check engine light never came on and it is showing no codes on my programmer. Also while pulling i had my programmer on the tow mode and i had less power and my exhaust temps were getting really high around 1300 to 1350 on level ground. Before i got to the grade i removed the programmer and changed it back to stock and i had a little better power with my exhaust temp running around 1250 to 1300 going up the grade. But i was still lacking power and my buddy left me in the dust. Caddy said he had some problems with his turbo sensors and i plan on taking it to the dealer. Any advice you can give me.
2005 CHEVY SILVERADO 2500HD 4X4
6" INCH FABTECH LIFT
AEM AIR INTAKE
4" INCH TURBO BACK EXHAUST
DIABLO PREDATOR PROGRAMMER
AMP RESEARCH POWER STEPS
MAGHYTEC DIFF COVER
20" INCH MAZZI WHEELS
TOYO OPEN COUNTRY TIRES
EGR AND RESONATOR BLOCKED
AUTOMETER PYRO AND BOOST GAUGES
luke0490 is offline   Reply With Quote
Old 07-18-2008, 08:39 AM   eBay Motors   #52 (permalink)
rock04max
Points: 1,098, Level: 12
Points: 1,098, Level: 12 Points: 1,098, Level: 12 Points: 1,098, Level: 12
Activity: 0%
Originally Posted by gr8shot View Post
If you limped your tranny, which it sounds like you did, that means its on the path to destruction. The stock tranny won't hold more than 90 or so hp for very long, runnin more than that is just a time bomb. Best bet is to put it back to stock, and change your tranny fluid and filter and hope for the best. From what everyone on here says, once you limp it, its going to happen again, and more frequently til your tranny is gone.
if you limp the tranny it will give you a code.
04.5 LLY crew cab, PPE program, custom air box, 4in. turbo back exhaust, and boost controller.
rock04max is offline   Reply With Quote
Old 07-18-2008, 08:45 AM   eBay Motors   #53 (permalink)
rock04max
Activity: 0%
how many miles does your truck have? How are your brakes working?
Old 07-18-2008, 10:42 AM   eBay Motors   #54 (permalink)
Pat@BD
Points: 1,999, Level: 18
Points: 1,999, Level: 18 Points: 1,999, Level: 18 Points: 1,999, Level: 18
Activity: 0%
Pat@BD's Avatar
Was there a lot of black smoke? How much boost were you seeing? It might be a turbo or egr issue.
Pat Stewart
Technical Sales
BD Power
www.dieselperformance.com
800-887-5030 ext. 101
Pat@BD is offline   Reply With Quote
Old 07-18-2008, 09:46 PM   eBay Motors   #55 (permalink)
luke0490
Activity: 9%
luke0490's Avatar
The truck has 41,000 miles on it and the brakes are fine. One thing i did notice was when i was going up hill and on the gas my boost gage went back forth from the 20 to about 5lbs of pressure about three times and the truck would lose power when the boost went down. It continued to do this until i let off the gas. You reminded me of this when you mentioned the boost. If it was a boost or egr problem wouldnt it throw a code? thanx guys for the help i need it. My truck dose smoke alot even when it was running good.
AEM AIR INTAKE
MAGHYTEC DIFF COVER
