2006 gmc coolant leaking - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 08-27-2010, 06:16 PM Thread Starter
Dmax7511's Avatar
my brothers gmc duramax is leaking coolant its tuned with a tune from duramax tuner and just started leaking and we cant tell where its from , any ideas?
Jeff
2015.5 High Country
Wcfab Twins , Exergy 10mm Cp3
Dmax7511 is offline
post #2 of 12 (permalink) Old 08-27-2010, 07:06 PM
blaineGMC's Avatar
Any more details you can give?
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
post #3 of 12 (permalink) Old 08-27-2010, 07:18 PM
If it's not coming out where it can be seen, perhaps it is internal, like a head gasket, or the EGR cooler. I'd check the later before the former. EGR cooler before head gaskets.
Any sign it's going out the exhaust? How much are you loosing? Can you smell it in the engine compartment? What HAVE you checked?
Ron Nielson
Ron Nielson is offline
post #4 of 12 (permalink) Old 08-30-2010, 07:35 AM
Storm59's Avatar
I have something not quite similar. i have a cooolant leak ever so slight. on the garage floor over night i see a puddle. at first I thought it was condensation from the AC. But then i noticed it was not evaporating like water should. it did feel a bit oily to the touch but does evaporate as the day goes by.
I did notice the DS Rad hose collapses after it is shut down for a while say about 3 hours or so.
I noticed the reservoir for coolant was slightly below the cold mark.
any tips on where i could start looking?
06 LBZ Silverado LT - Allison
Bullydog GT Tuner
K&N Intake
16" RaceOne Mags & Bridgestone Revo II
LED Dash Mod
Projector HID Lights High And Low with 4 light Mod
Rigid Dually LED Fog & Driving Lights
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
post #5 of 12 (permalink) Old 08-30-2010, 07:46 AM
ramonday's Avatar
I'd start by cleaning the degas cap in some hot water with soap. It has a relief that has to allow air back in once the system cools. It's the cap on the coolant reservoir. If you think about it, that collapse means your head gaskets are in pretty good shape.
2004.5 GMC Sierra SLT EC 2500HD 4x4 LLY w/LBZ MP, PCV reroute, EGR blocked, 4" exhaust, PacBrake TR sleeves, DSP5 & EFI-Live w/Idaho Rob tunes
ramonday is offline
post #6 of 12 (permalink) Old 08-30-2010, 10:15 AM
Administrator
jc1843's Avatar
Probably the water pump-- look at the weep hole - close to the lower hose.
jc1843 is online now
post #7 of 12 (permalink) Old 08-30-2010, 11:22 AM
cherokeechief's Avatar
if it is leaking toward the back of the engine, on the passenger side, it could be the cooling hose to the turbo. it is a 1/4' HOSE THAT COOLS THE TURBO.
had this happen with our 05. and of course if it is at the front of the engine it would be the water pump
cherokeechief is offline
post #8 of 12 (permalink) Old 08-30-2010, 11:52 AM
BmW745On19's's Avatar
This
It will get worse as time goes on. No it wasn't because of your tune. Mine went out just before 100k miles and started with just a weep hole and began to leak like a sieve.. The pump itself isn't expensive but the labor kills you. Its about $550 installed at employee prices. If you do it yourself it saves the labor but is a pita.
Get under your truck and flash a light around the front of the engine. Water pump is down on the driver side I think and will leak around the pully (on mine, at least).
2003 GMC Sierra 2500HD SLT 4X4 Duramax ECSB
Allison Automatic Transmission
Pewter Metallic / Pewter Leather
Mods:
285/75/16 Nitto Terra Grappler A/Ts
Edge CTS
XM Radio Commander
To Come:
4" MBRP Turboback Exhaust
BmW745On19's is offline
post #9 of 12 (permalink) Old 08-30-2010, 12:39 PM
Storm59's Avatar
Thanks I will look for that leak point. I am way overdue for a coolant flush do i will have it checked then
Bullydog GT Tuner
K&N Intake
LED Dash Mod
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
post #10 of 12 (permalink) Old 10-12-2014, 07:38 AM
I have a 2005 GMC with duramax and it is blowing coolant down passenger side of truck and is not running hot . we ran a pressure check for 4 hours and did not leak down at 20psi could this be a head gasket problem and how much to fix ? thanks
Dwayne2423 is offline
