| Premium Membership | |
| | | 04.5-05 LLY Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect |  |
07-11-2008, 06:57 PM
eBay Motors
#1 (permalink)
| | Senior Member
Join Date: Dec 2006 Location: lower mainland, british columbia, canada
| PPE settings? what level well im pickin up the PPE, very excited for the upgrade from the edge. my question is what levelw ill i be able to run it on?
can i run it on level 3 (120 hp) wen unloaded, and the level 2 (90 hp) tune when im towing my TT (about 8000lbs loaded).
or would you guys say thats to much for my allison.
i have a friend with the same truck ( 05 LLY) and he runs his on level 3 all the time ( 120 hp)
thanks for the help. Matt
__________________ 2005 Crew Cab Long Box LLY Duramax (silver birch)
PPE standard
Autometer Pillar Pyro and Boost
4" Stainless Turbo Back |
| Advertisement
07-11-2008, 07:37 PM
eBay Motors
#2 (permalink)
| | Senior Member
| the stage III is 160hp isn't it? I have the economy tuner and mine is 40-90-160. I would run stage II ans the allison can only handle up to 90hp. You dont want to cause issues..
__________________ 2006 Silverado Duramax
Ext. Cab Short Bed.
MBRP 4" C/B SS
PPE
Autometer Cobalt boost and Pyro
Hummer wheels with 285/70/17 Nitto Terra Grapplers
Whelen amber strobes on back rack with amber strobes in the grille.
Back Rack
Boss Plow |
07-11-2008, 07:42 PM
eBay Motors
#3 (permalink)
| | Member
| I agree, 90hp is about the max you want to run while pulling just to be safe I run mine on level 2 and have never had any problems. Hate to rip apart the trans$$$.
__________________ 2006 silverado CC silver birch kmc hoss 20's 305/50/20 nitto's s&b intake and amsoil oil. ppe economy tuner more to come... |
07-11-2008, 08:28 PM
eBay Motors
#4 (permalink)
| | Catch Me If You Can!
| Quote:
Originally Posted by BOOMER well im pickin up the PPE, very excited for the upgrade from the edge. my question is what levelw ill i be able to run it on?
thanks for the help. Matt | IMO you will be fine to run these levels. The PPE is rated at the crank so you will a little short of the 90 hp limit when on level 2 and right at it or just above when running level 3 you should be fine. Quote:
Originally Posted by OneBadDmax the stage III is 160hp isn't it? I have the economy tuner and mine is 40-90-160. I would run stage II ans the allison can only handle up to 90hp. You dont want to cause issues.. | Level 3 for a LLY like he has is 120 hp. Level 3 for a LBZ like yours is 160 hp.
__________________ KYLE
07-11-2008, 10:17 PM
eBay Motors
#5 (permalink)
| | Senior Member
| awesome, pretty excited to get this thing in! got gauges comin with it to!
will i notice more power on level 2 ( 90 hp) compared to my old edge on level 3 (75 hp) or will it be compareble?
just wonderin what to expect from the tuner, i guess smoother shifts and power? like whats better about the ppe!
PPE standard
07-12-2008, 12:48 AM
eBay Motors
#6 (permalink)
| | Duramax Forum Supporter
| Trust me you will notice it. I switched from an edge to my PPE almost a year ago and wow what a difference. Shifts are about the same maybe a little faster. However, in my opinion the throttle response was greatly improved over the edge. I am with big red in it should be safe to run it on the 120HP level. If your towing just watch the 4-5 or 5-4 gear shift. This will be the weakest spot for the factory trans and the most likely place to really slip.
__________________ 05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny |
| Advertisement
