| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | Transmission Shop Discuss the Allison OEM, After Market, And the ZF-6 speed. |  |
07-15-2008, 07:15 AM
eBay Motors
#1 (permalink)
| | Junior Member
| new tranny, need help deciding im looking into buying the ats stage two, comes with the 5 star converter and co pilot. anyone heard anything about these trannys? or better suggestions. im looking for it to handle about 500-600 rwhp. i appreciate any help |
| Advertisement
07-15-2008, 07:25 AM
eBay Motors
#2 (permalink)
| | Gear Jammer...
| IIRC the stage two is rated in the power level you want, i would run a ats trans in a min, I feel all the aftermarket kits out there are good kits, its usually the instalation of the kits that leads to problems when not done correctly. The Copilot IMO really isnt worth the$$ but others will disagree!
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
07-15-2008, 08:05 AM
eBay Motors
#3 (permalink)
| | DF Sponsors
| Quote:
Originally Posted by 05_LLY The Copilot IMO really isnt worth the$$ but others will disagree! |
It's not on a manual
We have two trucks that run the same HP(600+)/tuning/etc. at the track. One has a co-pilot, one does not. Both trucks have launched with the same 60'. The co-pilot truck will pull on each shift and beat the non co-pilot truck, but by only .07.
The co-pilot is not used on the street by me, so is 1100.00 worth .07, not really. The other thing to think about though, is my tranny has lived at these power levels for two seasons, is the co-pilot increasing line pressure enough to help? I feel yes. |
07-20-2008, 03:26 PM
eBay Motors
#4 (permalink)
| | Senior Member
| i got the stage 2 but i think the stage one would be plenty, and if you need it you could get the copilot later. i have no complaints about the tranny. talk to bryan he'll hook you up too
__________________ 01 lb7 ec sb ATS E POWER, ATS STAGE 2 w/ co-pilot ,FASS 150 GPH pump, mbrp 5", auto meter ultra lite guages airaid intake, billit grill
H2'S IN THE WORKS!!!! |
| Advertisement
