Bleeding Fuel to the Injectors? - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By smokinlmm
post #1 of 4 (permalink) Old 12-19-2010, 09:53 PM Thread Starter
rippinmax's Avatar
I just finished up replacing my head gaskets. I couldn't find any threads that could answer my question. Do I need to bleed my fuel system from the filter to the injectors? How would go about doing so? Thanks for the help in advance.
2005 Chevy Silverado 2500 Duramax with every bell and whistle GM offered - AFe Cold Air Intake - PPE Hot Standard Tuner Level 4 - EGR Block Off - ARP/PPE Head Studs - New Grade C Head Gaskets - MBRP 4" Downpipe back Exhaust w/5" Tip - 4" Rancho Lift w/ XL9000 Series Adj Shocks - 18" XD Rockstar Machined Black wrapped w/ 35" Toyo Open Country MT - many upgrades to come
Would Like to Thank Merchant Automotive for EXCELLENT Service!!!
rippinmax is offline
post #2 of 4 (permalink) Old 12-23-2010, 11:46 AM
ZX10Aviator's Avatar
read your manual, it says how to reprime the system. Yes, you will have to do it, a few times even to get it primed up.. Open the bleeder screw on top of the filter holder, pump the plunger a bunch, tighten the screw and try to start, do it until it starts.
-SOLD- '05 Sierra Duramax
* Just did HeadGaskets 10-30-2010 * Click for link
-Edge Juice with attidue, AFE Turbo inlet, Rerouted PCV, EGR Blocked and Fingersticked from KennedyDiesel, Grade C HeadGaskets, ARP Head Studs, looking for more mod advice, for longevity and better MPG
ZX10Aviator is offline
post #3 of 4 (permalink) Old 12-23-2010, 12:59 PM
Banned
If you are referring to bleeding the high pressure fuel system (after the CP3), then NO, you do not have to CRACK injector lines like on older diesel injection systems. You DO have to reprime the fuel system up to the injection pump with primer pump. Then just turn it over untill it fires.
rjrhoades likes this.
smokinlmm is offline
post #4 of 4 (permalink) Old 12-23-2010, 10:37 PM Thread Starter
rippinmax's Avatar
Thanks for the help!! It just took a cummins and 2 sets of jumper cables through a window of the garage. Now if only i would of payed attention to the return lines better it would be driving. Damn plastic Ts broke at the O ring inside the injector. Talk about a headache now that it's together. And finding them available was even worse. I have over 100 bucks just in 4 Ts but atleast she will be running strong again.
